SolaraGuy.com • View topic - Reverse to Drive and Brakes
Postby frohboy33 » Mon Mar 07, 2005 12:24 pm
I am getting a pretty good clunk when I shift from reverse to first when the car has just been started. After driving for awhile it seems better. Also my breaks squeek, but only the first time I break. After that Its fine no sound what so ever.
I had heard that these may be common problems, but nothing to worry about. Anyone else have these problems or have heard this?
13,000 miles
2003 Solara SE
I4 Automatic
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby Delshin » Mon Mar 07, 2005 6:37 pm
Not sure on the shifting, but the brakes, depending where you live, the disc gets moisture and or rust on it after sitting for a night. When you drive off and use it for the first time, the pads scrape that off and can cause some noise for the first couple of pedel press's
Delshin
Postby shawner2713 » Tue Mar 15, 2005 1:33 pm
Mine used to make some sort of crunching sound when backing out of the driveway and shifting to drive. But only on a cold engine. As far as i know it has since gone away and there are no problems.
shawner2713
Postby Jai_Jai_Binks » Tue Mar 15, 2005 2:48 pm
pretty much common probs, your brakes squeek as they have moisture buildup on the disc's (by spashing water from sprinkers or morning due). the clutch thing sounds normal too!
Postby lilm » Tue Mar 15, 2005 5:54 pm
when you say clunk its not a grinding noise...is it just real rough when you shift? cause that is a problem that might be eaisly fixed
http://www.toyotanation.com/forum/showthread.php?t=53223&page=1&pp=15
just do the opposite and see if it helps (remeber that the wire is a little loose)
lilm
Postby Grazi07 » Fri Mar 18, 2005 2:06 pm
When are you shifting? is the car still in motion while you're making the transition? I've heard of that happening before, its not a good idea
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby 1st Gen Sol » Fri Mar 18, 2005 7:22 pm
My brakes squeak on the first few times I step on them from the moisture or what not from over night......I heard that is a common problem but nothing to worry about. Don't know about that clunking noise though....
1st Gen Sol
Stock Sleeper
Stock Sleeper
