SolaraGuy.com • View topic - Resonator problem?
Resonator problem?
Resonator problem?
Postby SiegSolara » Mon Mar 07, 2005 3:57 pm
Hey guys, got another question
Whenever my engine is running at 2,800 rpm, I hear this awful buzzing/grinding like noise, its tough to explain. As far as sound effects, it sounds like 'BZzzzzzz'. Doesnt matter what gear Im in. The noise goes away above and below the 2700-3000 rpm range.
A friend told me its most likely the resonator going out, any second opinions? Thanks again.
SiegSolara
Postby frohboy33 » Mon Mar 07, 2005 4:30 pm
Does it happen only when coasting or accelerating? All the time? My buddies honda does that at about 2500 rpm he went and had it looked at and it was just the exhaust vibrating against the braces. He damped it and it went away.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby SiegSolara » Tue Mar 08, 2005 7:38 am
I notice the noise when Im accelerating, now that you mention it, I dont think it makes the noise (that Im aware of, anyways) when Im coasting at 2800 rpm...
I'll have to try it on the way home from work to be sure.
SiegSolara
Postby RichD978 » Tue Mar 08, 2005 7:45 am
i get that noise when im accelerating but i dont think it makes much of a difference
RichD978
Postby Jai_Jai_Binks » Tue Mar 08, 2005 8:34 am
a worn out resonator is like having an exhaust that makes it LOUD even at idle...a muffler shop can tell you for sure for free....
Postby DatSRBoi » Tue Mar 08, 2005 5:06 pm
Leak, worn out, or screws getting loose. My solara Number 2 does that until you go fast. It has loose screws.
Postby SiegSolara » Wed Mar 09, 2005 6:38 am
I'll take it to the shop and let you know if they come up with anything.
Thanks again guys
SiegSolara
