SolaraGuy.com • View topic - occassional strange smell
Postby mjk1666 » Sat Mar 12, 2005 7:42 pm
I have a 5 sp 00 SE w/ 64k. Recently, when shifting out of second at slow speeds or ideling, I've notice a strange burning rubber smell coming from through the vents. It only happens once in a while, but it definitely happens almost every time I drive. Is my clutch going bad? The car has been to the dealer for service twice in the past 3 months and they've never mentioned anything about the clutch (even thought they've mentioned everything else!) If I need a new clutch, how much would that be? Also, Where can I order the part for a good price?
mjk1666
Postby Jackass-Jeff » Sat Mar 12, 2005 8:06 pm
call and speak to a service writer. describe it and see if he'll give you some clue... most greedy asses won't give free advice... but it's worth a few minutes of your time.
1GR-FE ftw!
Jackass-Jeff
Postby Turbosolara » Sat Mar 12, 2005 11:05 pm
4 or 6 cylinder? 4 cylinder had valve cover gasket leakage problem after you pass 60000 miles mark
Postby mjk1666 » Sun Mar 13, 2005 3:18 am
It's a 4 cylinder. The smell is getting worse. Now it appears nearly everytime I get out of first gear.
mjk1666
Postby Paladin06Greg » Sun Mar 13, 2005 8:29 am
Milt nailed it!! Pay alittle now or a lot later..
--1LOKEDOUTSLE-- wrote:Could be the Clutch, take it to a Mech, and stop guessing what it is... None of us will be able to tell you.... Dont second guess...
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Turbosolara » Sun Mar 13, 2005 1:01 pm
actually check around if you got a plastic bag hang on your exhaust pipe first before you submit the car
Postby Jai_Jai_Binks » Tue Mar 15, 2005 2:50 pm
^^ haha, i had a plastic bag there in December. Even tho i removed everything i could see (and gain access to), i still smell that plastic at times....it can take 2-3 months to come off comletely!
Users browsing this forum: Google [Bot] and 28 guests
