SolaraGuy.com • View topic - CEL......here's the signs
Postby pythonjosh » Sun Mar 13, 2005 3:52 pm
Ok, so last night I gun it in first gear then at the next light my idle is bouncing from 600-800rpm. Then when I get to work last night it wasn't bouncing but it was idling at between 700-800rpm and it lost about 5hp. Then today on the way to work (I work 2 jobs) the check engine light comes on with no performance changes. Can anyone give me a good guess as to what I should check? Just don't feel like shelling out $85 just to get the CEL read. I was planning a 6 hour road trip on Tuesday until this happened. Thanks guys,
Josh
pythonjosh
Postby thakidd » Sun Mar 13, 2005 4:22 pm
autozone should read the code for free.....
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby pythonjosh » Sun Mar 13, 2005 4:40 pm
Oh yeah? I'll hunt one down. I know we have them up here. Thanks,
Josh
pythonjosh
Postby Turbosolara » Mon Mar 14, 2005 12:16 am
have you check if you blow any hose off? The code might be missfire if you have not change your spark plug at 60000 miles. Otherwise might be EGR, oxygen sensor or knock sensor
Postby 209solara » Mon Mar 14, 2005 9:03 am
id check all the vaccum lines, happened to mine too. possible an ignition coil, which wont pull a code
209solara
