SolaraGuy.com • View topic - Timming Belt Change 83K
Postby 99SEAUTO » Mon Mar 14, 2005 6:40 pm
Hey did anyone ever do you a timming belt change on your own, I have the parts including the water pump, and I am looking to do it saturday, anyone do it, I am just scared that im gona fk up my timming.
99 SE V6
99SEAUTO
Re: Timming Belt Change 83K
Postby bronzemaxell » Mon Mar 14, 2005 8:03 pm
99SEAUTO wrote:Hey did anyone ever do you a timming belt change on your own, I have the parts including the water pump, and I am looking to do it saturday, anyone do it, I am just scared that im gona fk up my timming.
take about 3 to 6 hours, i must say the hardest part is the crank pully nut, but if you have all the right tools, everything should be relatively easy,
if you replace with a new timing belt, you just need to line up the belt marks and cam shaft gear.
are drive belts and belt tensioner on your replacement list as well, besides the timing belt and water pump?
bronzemaxell
Postby SunGod916 » Tue Mar 15, 2005 2:12 am
I have a 99 SE Auto V6 too.
With the ugly 15" alloys! :-)
I would definately check the tensioner. If it isn't leaking I would suggest giving it a few pumps in a vice just to work it a little.
SunGod916
V6 timing belt
Postby PDX SuperSolara » Tue Mar 15, 2005 9:08 am
Having done several of these timing belts, I have to say this is one of the more difficult ones to get timed right the first time unless you have a lot of experience with this particular application. The good part is that it is a non-interference engine so you probably won't bend the valves if you get it wrong. Just keep trying until you get the timing belt on right, as you know it has to be perfect for the engine to run properly, the biggest pain is removing the tensioner and resetting the rod which has to be pressed in slowly and held in place with a pin.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
