SolaraGuy.com • View topic - Where is the jbl amp mounted
Postby Guest » Sat Nov 16, 2002 7:50 pm
99 SLE with JBL sound systems, where is the amplifier mounted?
Thanks
Guest
Postby Gunman » Sat Nov 16, 2002 8:43 pm
drop the glove box and up to the right. :wink:
Gunman
Postby nkx1 » Sat Nov 16, 2002 8:45 pm
It may depend on when your '99 SLE was manufactured; Mine is a '99 SE V6 with the JBL, manufactured in May of '99. My JBL head unit was self contained (the amp is built into the head unit itself). Although mine had the amp built in, I've heard other '99's may have a seperate amp. If the amp is seperate, I've heard its in the space behind the glovebox. You can tell by taking out the stock head unit: if there are 2 plugs in the back, there is no sperate amp. If there is 1 plug, the amp is seperate. :fadein:
2001 SLE, Diamond White Pearl
nkx1
Postby Guest » Sun Nov 17, 2002 7:41 am
Okey doke thanks. Hopefully I can get my Clarion taken out of the Camry LE and put in my Solara this week.
Guest
