SolaraGuy.com • View topic - two idlers 1 tensioner cam seal ???????
Postby 99SEAUTO » Sat Mar 19, 2005 7:55 am
Ok when I called the dealer today to ask what i need to change the timming belt he told me
Timming Belt
Cam Seal
Crank Seal
Water Pump
2 Idlers
1 Tensioner
Timming Belt-No crap, Water Pump-Ok
Is it necessary to change the freakin upper and lower idlers and tenioner or will it run fine without it?
99 SE V6
99SEAUTO
T/B change parts
Postby PDX SuperSolara » Sat Mar 19, 2005 9:48 am
Naturally the dealer replaces every part they can, in order to maximize profit but also to maximize rliability and prevent any future likely problem between T/B changes. I have rarely seen a water pump leak prior to the second T/B replacement and most people don't keep their cars that long anyway, same with the seals and tensioners. But anything is possible. So they are trying to hit every base. Except for the cost, that's not a bad thing. Generally, when people come into my shop for the car's first T/B change, if they are on a tight budget, I recommend changing only the belt, unless I see seepage from the seals or W/P or the tensioners feel loose or are getting noisy. On the second change, I usually recommend replacement of those items since they are so much more likely to fail prior to the third. I can raise the price a couple hundred dollars or more.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Jackass-Jeff » Sat Mar 19, 2005 10:13 am
These parts are recommended because labor is overlapping.
Paying 8 hours for the T-belt only is stupid... preventative maintenance on those other parts is part...
You end up paying 8 hours + t-belt and later end up paying another 8 hours and the other parts when they go bad... OR
you can end up paying 8 hours plus the extra parts and only pay 8 hours (maybe another hour more, depending on how legit they like to be)
1GR-FE ftw!
Jackass-Jeff
Postby importtuner2oo4 » Sat Mar 19, 2005 2:31 pm
it doesnt take 8 hrs to change the timing belt....more like 3-4 hours thats including the waterpump...
importtuner2oo4
Postby Jackass-Jeff » Sat Mar 19, 2005 2:37 pm
importtuner2oo4 wrote:it doesnt take 8 hrs to change the timing belt....more like 3-4 hours thats including the waterpump...
flatrate manual... actual time is about 3 hours
why help on the forum when everyone just snaps. fk it. pm me if i'm needed. ill just postwhore in the general areas
1GR-FE ftw!
Jackass-Jeff
Postby importtuner2oo4 » Sun Mar 20, 2005 10:56 am
the ONLY person snapping here is you. I was just going by how long it took me, thats all. Everyone is entitled to their own opinion if i remember correctly? :-?
importtuner2oo4
Postby Jackass-Jeff » Sun Mar 20, 2005 12:02 pm
fact vs opinion.
1GR-FE ftw!
Jackass-Jeff
Postby importtuner2oo4 » Sun Mar 20, 2005 2:11 pm
and the FACT is it takes 3 to 4 hours.
importtuner2oo4
Postby bronzemaxell » Sun Mar 20, 2005 5:13 pm
i probably won't do the cam seal and crank shaft seal until it leaks, but the parts are not expensive, but need special tools to remove those seals,
in my experience, dealer charge around $300 to $350 for the job, local shop charge around $250 to $300, DIY will be probably around 3 to 6 hours depend on the tools availability
bronzemaxell
Postby offthahook » Sun Mar 20, 2005 10:37 pm
importtuner2oo4 wrote:and the FACT is it takes 3 to 4 hours.
You obviously have no clue how mechanics or shops set their rates and get paid. Please open your own shop and set your own flat rates. :roll:
offthahook
Postby Jackass-Jeff » Mon Mar 21, 2005 7:34 am
Thank you! Someone that KNOWS! I was going to make a comment regarding the username, but I don't really have to x_x
1GR-FE ftw!
Jackass-Jeff
