SolaraGuy.com • View topic - chirping noise
chirping noise
chirping noise
Postby mjk1666 » Sun Mar 20, 2005 4:09 pm
2000 SE 4cyl 63K. When low gear (1st or 2nd) at slow speeds the car has a continual chirping noise coming from the front wheels. It seems to occur with every rotation of the wheel. Dealer said it was not a problem. Any insight into what might be causing it would be appreciated.
mjk1666
Postby DatSRBoi » Sun Mar 20, 2005 9:59 pm
If its the rotation, the best idea I can think of is how the tires are breaking in. Like the tires arnt even from being in the new side so it pops and cause the shocks or what ever to make sound. Nothing bad. Eventually the tires will shape out even and it will go away.
Postby adam2562 » Tue Mar 22, 2005 3:31 pm
is ur car manual?
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby DatSRBoi » Tue Mar 22, 2005 3:35 pm
Mine is...
Postby adam2562 » Tue Mar 22, 2005 8:22 pm
i mean the guy who opened the thread... cuz it veryu well could be his throw out bearing.. .. if the noise goes away when u push ur clutch in.. then its the throw out bearing.. if not then its wutever else
adam2562
Postby mjk1666 » Tue Mar 22, 2005 11:32 pm
The car is manual. The noice goes away above 2nd gear. What exactly is the throw out bearing? And is it bad that it chirps?
mjk1666
Users browsing this forum: Google [Bot] and 38 guests
