SolaraGuy.com • View topic - Emission Test Problems - OBD Unit
Postby yrunvus » Fri Mar 25, 2005 9:51 am
I just got my 1999 Toyota Solara and i had to go get an emission test on it to get it plated.
I took it for the test and it failed...the paper work said "cannot communicate with my OBD unit" I took it to a mechanic and he checked it out and he could communicate with my OBD unit. So he took it to the emission site himself and they had the same problem. Later, they finally called me said i'm missing pins 2 & 10 so i should call toyota and see what advice they have so as to test. In other words i'm on my own.
so, u guys ...any advice
1999 Toyota Solara 2.2L I4
yrunvus
Postby Mole » Fri Mar 25, 2005 10:36 am
who'd you buy the car from?
I would think the previous owner should of done an emissions check for you.
Postby yrunvus » Fri Mar 25, 2005 10:38 am
i bought the car from a dealer auction
yrunvus
DEQ Interface
Postby PDX SuperSolara » Fri Mar 25, 2005 6:57 pm
I would start at the interface, the recepticle that is, and see if the wires that are supposed to go to the missing pins are there. You could probably get a replacement one from a wreak and wire it in. Worse case you would need to replace the harness. Sometimes the pins themselves push out the back.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
