SolaraGuy.com • View topic - removing etched outline of emblem after shaving
Postby hari-bhari » Sat Mar 26, 2005 8:08 pm
hmm i wasnt sure where to post this since its not really an 'aftermarket upgrade'
anyhow, i shaved my emblems today, all but the toyota logo. i bought goo gone to get ride of the adhesive remainder
but now the problem is that there is this hard rough etched outline of the emblem where they used to be. i scrubbed but i couldnt get it off. i donno if its permanently etched into the paint or what
any ideas or tips?
and also, if i do have to reattach my emblems, does anyone know a good method?
hari-bhari
Postby rnsmelody » Sat Mar 26, 2005 9:58 pm
try using the claybar, that should help
rnsmelody
Postby hari-bhari » Sat Mar 26, 2005 10:05 pm
rnsmelody wrote:try using the claybar, that should help
good call!!
hari-bhari
Postby DatSRBoi » Sat Mar 26, 2005 11:34 pm
Is the clay bar really a bar? I saw somewhere there are liquid ones. Like Meguair.
Postby hari-bhari » Sat Mar 26, 2005 11:45 pm
they do make various liquids for things like tar removal, or insects. but the clay bar is actually a bar, and its the single most amazing detailing product ive ever used
hari-bhari
Postby DatSRBoi » Sun Mar 27, 2005 12:21 am
Ic Ic..Off topic allot but. When I wax the car, Am I suppose to do the swirl and scratch remover first then clay, or clay first then swirl and scratch remover? Its since I have the emblem tan line left over too like you, I might as well do the whole car waxing again.
Postby BradOwens » Sun Mar 27, 2005 8:20 am
yea i just clayed the part that left that outline and it came right out. im just glad it wasnt faded underneath
BradOwens
Postby Paladin06Greg » Sun Mar 27, 2005 8:42 am
3M Adhesive remove or cigarette lighter fluid works great.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Akfahad » Sun Mar 27, 2005 8:43 am
i'm assuming it's something you can pick up autozone or something like that, right? never heard of claybar...
Postby hari-bhari » Sun Mar 27, 2005 9:50 am
ok lets see..
first off, clay barring should be done after washing, but before anything else. typically if you clay bar the whole car, you would want to wash it again afterwards to get rid of all the lube and stuff you used.
the adhesive remover such as goo gone does a great job removing all sticky stuff left from the eblem's tape. however, there was this solid, rough, etched outline of the eblem still left on the paint. no amount of washing got rid of it, but the clay bar did. now you cant even tell anythign was there 8)
clay bar can be found sometimes at target, and if not any auto store. i prefer ordering things online from autopia though, much better products.
hari-bhari
Postby Akfahad » Sun Mar 27, 2005 10:17 am
Yeah, i had the same problem as you, i couldn't get off that faint resemblence from the emblems...but i'm definitely gonna go get that clay bar now.
Postby hari-bhari » Sun Mar 27, 2005 10:20 am
trust me, you will be amazed. i swear by the clay bar after using it just once. remember though, use LOTS of lube (if you run out, just use soapy water), and knead the clay bar constantly to expose a fresh surface. oh and if ur only using it to remove the etching, cut off and use like a 1 by 1 inch piece so u dont dirty the entire bar.
hari-bhari
Postby Paladin06Greg » Sun Mar 27, 2005 10:32 am
The problem with the claybar is you can "DAMAGE" your paint. I removed all my emblems on two cars using the lighter fluid/3M Adhesive Remover with no possible chance of paint damage.
Good luck!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Jon11582 » Sun Mar 27, 2005 11:53 am
Claybar does more than just that though. It gets EVERYTHING out included all that stuck in dirt. Anyone who washes thier own car should have some claybar anyways.
Claybar will not damage your paint unless you dont use enough lube. You can use any quick detailer as lube.
Most popular one is Clay Magic, and its in a blue/black box.
Id pick up some Meguiars Quik Detail along with it, since u can use it as extra lube, and QD is really useful in any case when you just need a quick "washed" look without the actual washing.
2000 Black Solara SE
Jon11582
Postby TRD_solaRa » Sun Mar 27, 2005 4:38 pm
did you guys ever use rubbing alcohol remove that rubber crap left over from the emblems? . . . i used it and had no problems, jus washed a cleaned the car afterwards.
TRD_solaRa
Users browsing this forum: Google [Bot] and 39 guests
