SolaraGuy.com • View topic - water-trickling noise not really gone
Postby hari-bhari » Tue Mar 29, 2005 10:28 am
last week i changed the coolant and since then i have been hearing this water running noise in my engine bay. i can hear it from inside my car, and its usually during a cold start. i checked the level in the overflow tank, seems to be fine. and the engine temp is fine, its not overheating. any idea what this noise could be?
hari-bhari
Postby hos01 » Tue Mar 29, 2005 10:41 am
I don't know if have had any replies on this but here is one 1 cne. Check the heater core. It might have internal leaks. it is located near the floor by the firewall. see if you here more noise in that section.
hos01
Postby Hsakuragi » Tue Mar 29, 2005 11:03 am
open the radiator cap, press the hoses and see if bubbles comes up, try to fill coolatnt director from radiator
Hsakuragi
Postby hari-bhari » Tue Mar 29, 2005 11:08 am
i did squeeze the hose, and bubbles to come out. but no matter how many times i squeeze all the bubbles out, and close the cap, next time i check, always more bubbles
hari-bhari
Postby SleeperSolara » Wed Mar 30, 2005 8:10 am
You should drain it again if you want to.
And then run some regluar water throught the system, wit the radiator plugs open.
And make sure it nice and clear then put hte radiator fluid back in.
That should work.
Did you have the heater runnin' wit hte car runnin' to open up the themostat and whatnot for the engine.
You have to fun the car for awhile to let the water circulate in the coolant system.
Postby Turbosolara » Wed Mar 30, 2005 10:38 pm
If you had so many bubble, maybe you did your radiator flush wrong, do it over again.
you suppose keep squezz the lower radiator pipe and continuely adding water with car running and full blast of heater. you stop after you dont see anymore bubble.
Postby hari-bhari » Thu Mar 31, 2005 1:55 pm
haha how ironic that i screwed it up after i was the one who wrote the tutorial
hari-bhari
Postby Hsakuragi » Thu Mar 31, 2005 2:44 pm
:rofl:
need to rewrite it...?
Hsakuragi
Postby xavier » Mon Apr 04, 2005 6:31 am
for some reason I cant get all the air out....Still makes the noise after my flush...This is annoying to no end
xavier
Postby hari-bhari » Tue Apr 05, 2005 12:31 pm
so i went to the dealership today. they said sometimes an air bubble gets trapped like that in the heater core. no danger, it will get rid of itself.
hari-bhari
