SolaraGuy.com • View topic - Wiring through headlight system
Postby xyntax » Wed Nov 20, 2002 1:03 am
Does anyone here know where and how to wire something so that when you switch on your headlights, the accessories wired to it would turn on too?
If that's going too much trouble, maybe I should just stick with the old cig lighter plug way.
I have this thing about lights in my Solara's interior :bday: . Anyways, it's still just a plan. Haven't done anything yet.
Thanks for the inputs!
ps. I have an 02 Solara
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby ZXLNT » Wed Nov 20, 2002 9:50 am
You could just tap off the headlight relay to another relay. The headlight relay will trip that one to power whatever you want. Use a 30 amp relay wiring the field coils to the 12V going to headlights and the other end to ground. The contacts will be wired to the battery and the other end to the 12V side of whatever you want to power.
ZXLNT
Postby 4banger » Thu Nov 21, 2002 9:24 pm
since solaras have daytime running lights, wouldn't it make more sense
to run it off the fog lights since you can turn them off and they won't dim.
4banger
Postby xyntax » Fri Nov 22, 2002 2:09 am
4banger25 wrote:since solaras have daytime running lights, wouldn't it make more sense
Good point! But I have decided to just use the cigarette plug connected to a switch for convenience (and safety). I think I'm too chicken to tamper with internal wirings in my 02 right now. :( I'll learn...
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby Missay » Fri Nov 22, 2002 1:09 pm
Xyntax wrote:I think I'm too chicken to tamper with internal wirings in my 02 right now. :( I'll learn...
hey, take "dawizard" into account here! remember he played w/ the pins on his rpms and stuff and now it's messed up? need i say more!
heheh..we should learn from other solaraguy's mistakes!
Melissa
Missay
SolaraGuy Ambassador
Postby Yanks0114 » Fri Nov 22, 2002 3:41 pm
What are you trying to connect and if you can plug it into your cigarette ligther, why not just cut off the end and hardwire it into your fuse box. Its extremely easy. I'll take pics if u'd like
Postby xyntax » Fri Nov 22, 2002 5:40 pm
I would appreciate that yanks! thanks! I'm open for suggestions.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby nkx1 » Fri Nov 22, 2002 8:57 pm
One easy thing you could do is tap into the illumination lead from your stereo to trigger a relay.
2001 SLE, Diamond White Pearl
nkx1
Postby Yanks0114 » Sat Nov 23, 2002 5:48 pm
What are you trying to connect btw? i'll have pics up later this weekend
Postby xyntax » Sat Nov 23, 2002 8:50 pm
yanks0114 wrote:What are you trying to connect btw? i'll have pics up later this weekend
Oh just lights inside. I'm still experimenting, haven't really acquired most of it yet. I just dont want to go through the cigarette plug coz i hate how the wires would show outside. My goal is to conceal the wirings, making the lightings look seamless in its installation.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby xyntax » Mon Nov 25, 2002 12:03 pm
:( uhh... I'm having trouble identifying which one is the fog light connection in my O2's fuse box. Can anyone show me? Thanks
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
