SolaraGuy.com • View topic - emblem's glue!
emblem's glue!
emblem's glue!
Postby krook » Wed Nov 20, 2002 1:54 pm
i removed my 'toyota' wording emblem, and the toyota sign emblem, so only SOLARA is still on. however, the glue from the toyota sign is still stuck on! how do you get rid of it!?! will goo-gone work?
krook
Postby Jackass-Jeff » Wed Nov 20, 2002 2:26 pm
i helped richard remove his
The floss should have taken off the TOYOTA and left the tape ouline of TOYOTA. to get that off, just blow dry it some more so the glue softens then peel with your hands. After that, just get a paper towel, wet it, and run gently so make sure all the little particles get off
I guess you can use goo gone, but we did it w/o any and it came off perfectly
1GR-FE ftw!
Jackass-Jeff
Postby NASTY » Wed Nov 20, 2002 2:51 pm
i used goo gone, worked really well
but if itll work without like xravexboix said, just do that
'01 SLE V6
NASTY
Postby krook » Wed Nov 20, 2002 2:52 pm
well, i took it to the body shop and those pricks look like they used superglue (hellllooo!) with the tape to put it back on! so will goo-gone get rid of that!?! i tried the blowdry method, and it seems that it won't soften up. whadya think?
krook
Postby Yanks0114 » Wed Nov 20, 2002 4:14 pm
krooked Solara wrote:well, i took it to the body shop and those pricks look like they used superglue (hellllooo!) with the tape to put it back on! so will goo-gone get rid of that!?! i tried the blowdry method, and it seems that it won't soften up. whadya think?
Goo gone should definately work. Thats great stuff. Heat up the glue as was said above, then use goo gone, and then rub it with your hands
Postby krook » Wed Nov 20, 2002 6:50 pm
i hate to say it, but it really looks like superglue on the body. i have this solvent degreaser that'll remove anything at work. it'll probably get rid of pimples if ya rub hard enough! do you guys think that'll remove it? or do you know anything that will remove superglue from the body?
krook
Postby Gunman » Wed Nov 20, 2002 7:58 pm
wd-40 works great in those situations.
Gunman
Postby Missay » Wed Nov 20, 2002 8:37 pm
Gunman wrote:wd-40 works great in those situations.
ahhhhhh..the power of wd 40 :)
Melissa
Missay
SolaraGuy Ambassador
Postby c2g » Thu Nov 21, 2002 10:14 pm
I put just a little goo gone on paper towel and rubbed it right off then washed it right away worked great
99 silverstream SE V6 18" RSL nengans, Streetglow head and fog lights, Reverse guages,
Kicker L7 12" DVC, MTX amp, panasonic 903U, sirius, shaved emblems, clear corners,
altezza tails, K&N filter, mesh upper & lower grill so far
c2g
Users browsing this forum: Google [Bot] and 19 guests
