SolaraGuy.com • View topic - Automatic Window
Automatic Window
Automatic Window
Postby ~Spadwaller~ » Thu Apr 07, 2005 5:07 pm
My passanger side window is making alot of noise can I just lube it up with WD-40 or do I have to buy a replacement motor or perphaps some other solution?
~Spadwaller~
Postby Chris A » Fri Apr 08, 2005 12:24 am
If you are going through the trouble of pulling the door panel a good grease will last much longer then WD40..
Those things are pretty well greased at the factory though so I would suspect that something is either lose or the motor or gears are going bad.
Women can fake orgasms but men can fake whole relationships.
Chris A
Postby Jai_Jai_Binks » Fri Apr 08, 2005 8:00 am
mostly when the regulator goes, the window slides down as usual, it just doesn't slide back up normally! (thats been my usual suspect).
Sounds
Postby ~Spadwaller~ » Fri Apr 08, 2005 8:54 am
It sounds like gears in there, other than that it opens and closes fine. Anyone know how many bolts there are to the side panel?
~Spadwaller~
Postby hskrsolara » Fri Apr 08, 2005 9:17 am
If it sounds like something is grinding in there, it is probably your regulator. Thats how mine sounded and the grinding was actually caused by the regulator cable getting off the pulley and banging around in the door. I would reccomend just replacing the whole regulator so you dont have to worry about it anymore. On the door, there are several clips around the bottom, and also 2 screws on the bottom. Right next to the door hinge there is another screw with a cover on it. Also remove the screw in the door handle assembly, you will see a little square cut out to open to get to the screw. Two left, there is one in the bottom of the small cup/handle used to close the door. Then you will need to take out the switch panel and below there is the final screw, holding the whole panel to the door. Take this out and voila! Sorry if this seems really long and confusing, but actually the process is very easy!
hskrsolara
Thx
Postby ~Spadwaller~ » Fri Apr 08, 2005 10:27 am
Not confusing at all thanks. To get this regulator I assume I have to goto the dealer.
~Spadwaller~
Postby Jai_Jai_Binks » Fri Apr 08, 2005 12:04 pm
there are posts here how to remove teh door panals (HINT HINT: speaker replacement)...as for the regulator, just grease and see if it works....
Users browsing this forum: Google [Bot] and 39 guests
