SolaraGuy.com • View topic - What kind of Jack do you use?
Postby Jon11582 » Sun Apr 10, 2005 1:30 pm
What kind of Jack do you use to work under your car?
I'm going to need a jack soon to put my catback on, and just wanted to see what methods the rest of you use.
2000 Black Solara SE
Jon11582
Postby jazzlara » Sun Apr 10, 2005 1:52 pm
2 .25 ton hydrolic jack. does the job.
jazzlara
Postby bassthrive » Sun Apr 10, 2005 2:07 pm
2 ton hydraulic, got it for $20 at advance auto parts. you may also want to invest in a creeper for your exhaust install. got one at walmart for under 20.
i used ramps up front and jackstands in the rear when installing mine. i dont know what type of environment you have been driving in but i do know that 4 years of riding through snow and rain and salt in New York rusted my exhaust pipes and fittings to hell and back. i had to cut off the bolt heads at the cat back junction with a dremel - really tedious work. be sure you use antisieze on the new bolts in case you ever need to work under there again.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby TadS » Sun Apr 10, 2005 4:43 pm
2 Ton Craftsman hydraulic with a full set of jack stands.
TadS
Postby Mole » Mon Apr 11, 2005 11:45 am
napa auto parts jack.
lower profile so it can get to lowered cars.
Postby Paladin06Greg » Mon Apr 11, 2005 11:48 am
DITTO!!
TadS wrote:2 Ton Craftsman hydraulic with a full set of jack stands.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby jazzlara » Mon Apr 11, 2005 11:49 am
Mole wrote:napa auto parts jack.
^^ you pimp you :D
jazzlara
Postby quikz » Mon Apr 11, 2005 4:17 pm
Paladin06Greg wrote:DITTO!!
samething here, mine leaks oil :)
01 blk SLE
quikz
