SolaraGuy.com • View topic - messed up turn signals
Postby AzN_DrAgoN48 » Sun Apr 10, 2005 9:57 pm
so just recently my turn signals stopped working. but i checked the relay and i check the fuse and they are all fine. sometimes they work when i start my car in the morning but then 5 mins into a drive they shut down again. sometimes when i hit the hazards they would start working again. the hazards always work by the way. any ideas?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby Fenix » Mon Apr 11, 2005 5:37 am
Loose connector, maybe? or could it be the light bulb itselt? If you haven't done anything to the electronic system recently such as installing lights, modifying your dashboard, installing your stereo, so on, then it must be the problem with the signal light.
Just take it out and check it.
R.I.P baby.
Here come the black on black 5spds. New era....
Fenix
Postby AzN_DrAgoN48 » Mon Apr 11, 2005 5:38 am
i did do all three of those. how do i check the connection? i installed hids, a stereo and i did new lights to the dashboard. where should i start to go in?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Yanks0114 » Mon Apr 11, 2005 2:57 pm
sounds like the hazard light connector is loose. Check that first(you would have had to remove it when u installed the stereo)
Postby AzN_DrAgoN48 » Mon Apr 11, 2005 5:14 pm
the hazards are fine, they always work. however the actually turn signals bar doesn't work. whenever i press down nothing happens and when ever i push it up it doesn't work
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Solorange » Mon Apr 11, 2005 7:54 pm
I had this problem with my camaro. The problem was the flasher. The hazards on my camaro use a different flasher, than the turn signals. That may be why they work fine. Im new to toyotas, but that could be something to check into.
