SolaraGuy.com • View topic - ABS light turns on and off
Postby lazyboyz69 » Thu Apr 14, 2005 3:40 pm
when i'm driving the ABS light will go on sometimes, then when i turn off my car and turn it back on again the ABS light won't be on....
I just got my tires changed..... can that be a factor or the senor is loose?
lazyboyz69
Postby SleeperSolara » Fri Apr 15, 2005 7:58 am
Probably
Postby Whatever » Fri Apr 15, 2005 10:35 am
that should be the problem, go to the tire shop and ask em to check it for you. or you can take off the wheels and check by yourself
Whatever
Postby SolaraGuy22 » Fri Apr 15, 2005 11:24 am
Mine has come on like that a few times but that's after a mad rain. I figured something gets wet and once it dries It's okay. What I have noticed is my air bag light staying on for a while. I'll search for that in a bit.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby boneezy » Fri Apr 15, 2005 12:19 pm
SolaraGuy22 wrote:Mine has come on like that a few times but that's after a mad rain. I figured something gets wet and once it dries It's okay. What I have noticed is my air bag light staying on for a while. I'll search for that in a bit.
My airbag light stays on too.. I tried taking it to the $tealer and they were trying to charge me $80 for the diagnostic.. screw that
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby Chris A » Sat Apr 16, 2005 12:42 am
I paid the $80 and they found that the sensor under the drivers seat was bad..
See if you can clear the code.. Remove all the beer bottles from under the seat and see if it comes back.
Women can fake orgasms but men can fake whole relationships.
Chris A
