SolaraGuy.com • View topic - how to run power cable though from inside to battery
Postby pc212 » Sun Nov 24, 2002 1:54 am
i can't find no opening from the firewall to run the power cable from the amp to battery, or do i have to drill?
please help thanks
:drinking:
ps: 03 solara
pc212
Re: how to run power cable though from inside to battery
Postby impactX » Sun Nov 24, 2002 5:19 am
pc212 wrote:i can't find no opening from the firewall to run the power cable from the amp to battery, or do i have to drill?
please help thanks
:drinking:
ps: 03 solara
There's an opening at the daytime running light plug... There's a rubber piece there, pull it out and there's a hoe to run a cable thru. You will have to make an opening on the rubber piece though.
impactX
Postby nkx1 » Sun Nov 24, 2002 9:32 am
Here's a picture I took of my power cable routing. I peeled off some of the split loom tubing so you can see exactly where the cable runs. The large cable is my amp power, and the little wire is for my alarm.
http://photos.yahoo.com/bc/nkx1/vwp?.di ... t&.hires=t
2001 SLE, Diamond White Pearl
nkx1
Postby ericatdallas » Sun Nov 24, 2002 8:00 pm
I can't see the pic but the description sounds right. you have to cut the nipple or just make a whole somewhere on the rubber thingy.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
