SolaraGuy.com • View topic - 5S-FE: Coolant Bypass hoses?
Postby SeanJohn0716 » Wed Apr 20, 2005 6:17 pm
Which hoses on he TB do you connect together to bypass the TB?
SeanJohn0716
Postby Mole » Wed Apr 20, 2005 7:03 pm
Whats the TB ?
Postby bassthrive » Wed Apr 20, 2005 7:42 pm
TB = Taco Bell
i know the coolant hoses feeding the throttle body of the 1mz are on the very lowermost part of the assembly (had to remove intake piping to access it). You want to disconnect those from the tb and join them with a 5/16 barb fitting. Pull the hoses and see if coolant comes out. I guess you could also run the engine for a while and see which ones are hot? (tho definately let the engine cool completely before attempting to disconnect anything)
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Turbosolara » Wed Apr 20, 2005 9:48 pm
are you talking about the coolant line goes near by throttle body?
Postby Fletch » Thu Apr 21, 2005 4:19 am
It's fun to do small cheap mods to your car but I don't think this is worth the trouble, plus the gains are not noticable on a "seat of your pants" dyno. My roommate and I both did this a while back and switched it back for the winter. Unless your hands are tiny, not much room to work on the 1mz.
Just my 2 cents, some claim to have noticed better response.
2006 Legacy GT spec.B
Fletch
Postby bassthrive » Thu Apr 21, 2005 5:47 am
yeah i didnt notice any power increase when i did this.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SeanJohn0716 » Thu Apr 21, 2005 6:01 am
Ok then, I'll just leave it be. Thanks
SeanJohn0716
