SolaraGuy.com • View topic - guage bulb #?
guage bulb #?
guage bulb #?
Postby RichD978 » Thu Apr 21, 2005 5:50 am
anyone know the bulb # for the turn signals behind the guage. I took the green circle off and now i get blinded by the amber . are those bulb normal sizes? seems like 74
RichD978
Postby Duffman » Thu Apr 21, 2005 7:02 am
Check the Gen 1 - 1.5 Tutorials forum, there's a complete lighting guide there that will give you plenty of information on the bulbs. I do believe they're #74.
If you're looking to swap them out, try http://www.autolumination.com/, or if you're electric-savvy, you can pick up the actual LEDs and do your own stuff at http://www.lsdiodes.com/. I've heard several people here have had good experiences with AutoLumination, and I've used LSDiodes for computer modding on several occasions - they pack their lights well and they've got good customer service. Either one will do you well.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Re: guage bulb #?
Postby Jon11582 » Thu Apr 21, 2005 7:21 am
RichD978 wrote:anyone know the bulb # for the turn signals behind the guage. I took the green circle off and now i get blinded by the amber . are those bulb normal sizes? seems like 74
Any bulbs going to blind you with nothing between you and the bulb.
All you gotta do to keep from being blinded is to take off the black bezel, rip a corner out of a sheet of paper, wrap paper around the column where the turn signals are and the green circle used to be, and rubberband it to keep it on. It'll be whitefaced turn signals, and the light wont blind you.
I believe the size is officially 2721, but 74 is much more common and will fit. (FYI, 74 has a very slightly bigger base, but it will fit in a 2721 bulb slot, snuggly)
2000 Black Solara SE
Jon11582
Postby RichD978 » Thu Apr 21, 2005 9:17 am
Duffman wrote:Check the Gen 1 - 1.5 Tutorials forum, there's a complete lighting guide there that will give you plenty of information on the bulbs. I do believe they're #74.
i checked couldnt find it so i checked here... thanks
RichD978
Postby 1st Gen Sol » Tue Apr 26, 2005 8:53 pm
If you go to your local Pep Boys, there is a book in the isle where the replacement bulbs are located with every car manufacturer, make and model with all the bulb numbers listed next to each year & model of the car.
You might also perhaps be able to check it of there website.......If anything just give them or any local automotive shop and ask they'll be able to look it up for you.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby bassthrive » Tue Apr 26, 2005 9:06 pm
They are 74, and if you dont like the whiteface look you can do what I did and cut out circles of window tint to replace those green plastic disks.
I have two layers of 20% over red bulbs for my signals now and it looks nice. If I had to do it again I might even do 3 layers.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
