SolaraGuy.com • View topic - Strut Install Need New Strut Bearings?
Postby jdsun1 » Tue May 03, 2005 10:22 am
The place Im going to said that I need new strut bearings when I get my tokico/eibach strut/spring combo put on.
Anyone know where to buy these or what kind?
jdsun1
Re: Strut Install Need New Strut Bearings?
Postby jdsun1 » Tue May 03, 2005 11:36 am
Its like 30 bucks at toyota... Just go to a dealer, at least thats how much they are out here at Hamer Toyota.....
Do you recommend me getting these? Will it help with the noise/performance?...Also it seemed like he was saying I should get some aftermarket performance ones or something.
jdsun1
Postby jdsun1 » Tue May 03, 2005 1:18 pm
--1LOKEDOUTSLE-- wrote:Well if they are falling apart or open, then yes I recommend you get new ones for about 30 bucks each......
I doubt there are any aftermarket performance bearings, lol, it sounds funny...........
Just go to toyota.........
Going to toyota to get some. Thanks for the help. For 30 bucks its worth not have that loud clunking noise.
jdsun1
Postby lazyboyz69 » Tue May 03, 2005 4:20 pm
i don't have them on my car... the rubber things on top of the spring....
lazyboyz69
Postby jdsun1 » Wed May 04, 2005 8:14 am
66.50 for a pair at the dealership...ouch! :-?
jdsun1
Postby WTF?? » Wed May 04, 2005 12:34 pm
u should be able to use your current ones for a long while before they go bad. I had to replace mine since I angle my car on inclines all the time and all that pressure that it takes... but Milt is right... should be around $30
remember to get an alignment after youre lowered
Retired... its been fun Image
WTF??
Postby Whatever » Wed May 04, 2005 1:27 pm
jdsun1 wrote:66.50 for a pair at the dealership...ouch! :-?
isn't that 33.25 each? not so bad.
Whatever
