SolaraGuy.com • View topic - Door Panel noise
Door Panel noise
Door Panel noise
Postby Mdawg0510 » Tue May 03, 2005 8:05 pm
Ok so this is the deal, i have subs and there is a horrible high pitch squeek coming from inside my left door panel i know soemthing is just loose i just dont know how to get the damn thing off and to get it off right. and im also interested in knowing how u all dampened the sound like dynamat and such?
Matt
Mdawg0510
Postby SleeperSolara » Wed May 04, 2005 7:46 am
Post in Correct Forum; [under audio].
Anyways, what kind of squeak??
1. Well to get the door panel off; you need to look at the bottom of the door and there should be three 12mm bolts. Put those bolts, in the floor near the door.
2. and then you move to the area near the side view mirror, then use a flat head, and pry off the plastic panel.
3. Then move to the pocket of the panel switch for the door locks, and windows; and pry off the carpet thingy in the little pocket [where you can hold on to the door to shut it, when you get in] pry that off wit a flat head.
4. Then you will se a phillips head, and of course use a phillips to get that loose.
5. Then you use a flat head and pry off the panel, but be careful cause you can break the tab to hold it in place, once you have that out, aunplug the plugs for the window switch and door switch [1 plug for that]. Also leave the screws in the pocket thingy so you don't lose it.
6. The you will se a bolt that is hold the panel in the middle in place, that is 12-14mm bolt and unbolt that.
7. Now for the door latch, pry off the cover in the recessed area, and use a phillips, to get the screw out.
8. Then you pry off the panel for the door latch off, near where the door latch swings by. Leave the screw for that in the rescess area of the door latch panel.
9. then look near the front of the door, where there is a recessed area, and pry off the circluar cover and use a phillpes to get it out.
10. Then you can hold the hole near where that panel cover for the window switchs and door lock switchs, and give it a slight pull, and it should pop out at the door in the front and bottom, and rear, then when you have it loose on front bottom and rear, pull it up and you have the door panel off.
Look online about eh sound dampendin' stuff, it like applyin' stickers, but a thick one.
