SolaraGuy.com • View topic - Brake light in the dash...
Postby KRNguyW/aSOLARA » Thu May 05, 2005 11:37 pm
Just wondering if you guys have this problem too... While im driving, at RANDOM times when im not even pressing the brakes, the brake light in the dash comes on. And yes, the e-brake is down all the way... Sooner or later it goes away. And sometimes comes back. Any ideas? Thanks.
RED '99 SE V6 5-SPD--STOCK (at the moment)
KRNguyW/aSOLARA
Re: Brake light in the dash...
Postby SpeedSTARs » Thu May 05, 2005 11:43 pm
KRNguyW/aSOLARA wrote:Just wondering if you guys have this problem too... While im driving, at RANDOM times when im not even pressing the brakes, the brake light in the dash comes on. And yes, the e-brake is down all the way... Sooner or later it goes away. And sometimes comes back. Any ideas? Thanks.
You might want to check the brake fluid... It might be low.
-G :angel:
SpeedSTARs
Postby Ford_Fixorrepairdaily » Fri May 06, 2005 12:40 am
had the same thing happen. the brake fluid was just low so check that out.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby KRNguyW/aSOLARA » Fri May 06, 2005 1:01 am
thanks, i'll check it first thing tmrw.
KRNguyW/aSOLARA
Postby RichD978 » Fri May 06, 2005 2:56 am
yeah brake fluid is low
RichD978
Postby xsolara33x » Fri May 06, 2005 8:22 am
make sure you check your brakes also, your fluid might be low cuz your brake pads are wearing down, when you brake pads are low it uses more brake fluid... correct me if im wrong guys...
raphael
xsolara33x
Postby RichD978 » Fri May 06, 2005 8:27 am
^^ Si Senor u are mucho correcto. Mui Bienos
RichD978
Postby SpeedSTARs » Fri May 06, 2005 9:18 am
xsolara33x wrote:make sure you check your brakes also, your fluid might be low cuz your brake pads are wearing down, when you brake pads are low it uses more brake fluid... correct me if im wrong guys...
raphael
Right on the money Bro. Another reason this type of thing happens is due to the the fluid being low is due to the heavy braking. Heavy braking burns up the brake fluid due to the heat and cooling the fluid endures. It is more so if the car is used for endurance racing. As the fluid ages, the fluid losses it properties continue this cycle of cooling the braking system (Basiclly water gets into the fuild which contaminates the liquid-watered down stuff). In general, it is best to have the system bled around 60,000 miles. Unless you are running a DOT5 or higher grade of brake fluid, the intervals are longer. As always, happy to help my fellow Solara brothers and sisters. :P
-G :angel: :angel:
SpeedSTARs
Postby 1st Gen Sol » Fri May 06, 2005 1:30 pm
RichD978 wrote:^^ Si Senor u are mucho correcto. Mui Bienos
^^^^ No Habla Espanol........lol
I had that problem before......check the brake fluid along with what "xsolara33x" said.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Anthony » Thu Jul 07, 2005 6:29 pm
Hey everybody,
I experienced the same issue as described by KRNguyW/aSOLARA. I checked the brake fluid level and it was indeed low. The light went away after I added some more brake fluid, but it came back after a few weeks. My front brakes are relatively new, but my back brakes are not. Anyway, I took the car in to the dealer and paid for a brake inspection just to make sure that everything was OK (I travel really far to work everyday on the freeway, so I don't want to risk anything). They told me that the brakes are fine (couldn't find any leaks or issues) and simply topped off the brake fluid. It's been a few weeks now and the light is coming back on. Obviously I'm going to add more brake fluid, but is this normal? As I indicated earlier, most of my driving is on the freeway and I rarely brake really hard. Any suggestions or feedback would be greatly appreciated. Thanks!
Anthony
2002 Solara SLE
Anthony
Postby StockSolara » Thu Jul 07, 2005 6:49 pm
That is quite off maybe you have a leak some where. . . just cause the dealer says something doesn't mean it's true so just double check yourself after using your brakes for any places that might seem to have a leak
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SpeedSTARs » Sun Jul 10, 2005 10:04 pm
StockSolara wrote:That is quite off maybe you have a leak some where. . . just cause the dealer says something doesn't mean it's true so just double check yourself after using your brakes for any places that might seem to have a leak
I agree with StockSolara... You should have this checked out by a trusty mechanic. There might be a leak in the braking system. I had the same problem for awhile. I was refilling the brake booster reservior every two months or so. This all stoped when I swapped out the brake lines with the Goodridge stainless steel lines.... Most definely have those lines checked out. Godspeed Bro. :wink: :angel:
SpeedSTARs
Postby RichD978 » Mon Jul 11, 2005 3:26 am
I would go to midias or meinike, they are real good on brakes.
RichD978
Postby Anthony » Tue Sep 20, 2005 6:33 pm
Update: I went back to the dealership and told them that my brake fluid level keeps dropping even after adding more fluid. They checked my brakes again and told me that I needed new brake pads and rotors in the rear (even though they told me the brakes were fine a few weeks earlier when I paid them for a brake inspection). Anyway, the brakes were worn, so I figured after the replacement, the fluid problem would go away. Well, it hasn't. I checked for leaks myself and I can't see any place that might be leaking. I have no problem replacing the brake lines as SpeedSTARs mentioned above, but how do I know that they need to be replaced? I have about 102,000 km (~63,380 miles) on my car right now.
Anthony
2002 Solara SLE
Anthony
Postby Hefty » Thu Sep 22, 2005 2:10 pm
SpeedSTARs wrote:Right on the money Bro. Another reason this type of thing happens is due to the the fluid being low is due to the heavy braking. Heavy braking burns up the brake fluid due to the heat and cooling the fluid endures. It is more so if the car is used for endurance racing. As the fluid ages, the fluid losses it properties continue this cycle of cooling the braking system (Basiclly water gets into the fuild which contaminates the liquid-watered down stuff). In general, it is best to have the system bled around 60,000 miles. Unless you are running a DOT5 or higher grade of brake fluid, the intervals are longer. As always, happy to help my fellow Solara brothers and sisters. :P
-G :angel: :angel:
A stock braking systems isn't going to produce the kind of temps that will cause a noticible loss of fluid from boil off even under heavy braking. The level in the reservoir will go down because of material being ablated from the pads, Loss of rotor thickness, air in the system somewhere, or a leak in the system.
Brake fluid doesn't need to go through repeat thermal cycles to absorb water content. It is just a natural absorption of water vapor from the outside air. Older fluid will contain more water and therefore will lose its compressibility properties which can contribute to a mushy pedal feel and introduce corrosion of your brake system. Please, DO NOT put anything other the prescribed DOT3 brake fluid in your car. Putting the wrong rating fluid in your car can result in brake failure. The performance gain is going to be negligible on stock braking system anyways so it is not worth it. Primarily race car drivers go up to high DOT rated fluids to prevent boil off or brake fluid fires under extreme braking scenarios. But I am talking about calipers that have 5 pistons and enormous drilled rotors to produce those kinds of energies.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
