SolaraGuy.com • View topic - Rear Bumper
Rear Bumper
Rear Bumper
Postby gdzilla » Mon May 09, 2005 6:11 pm
I was parked outside a store tonight and someone ran in to my rear bumper. There's a big dent on the drivers side by the tailight. I was wondering how easy it would be for me to remove the bumper and pop the dent back into place? Any instructions would be great!
gdzilla
Postby trdkamuri51o » Mon May 09, 2005 7:14 pm
6 bolts remove the plastic panels on the inside of the trunk and u should see them run along the edge. i think 10mm remove them and the plastic clip on the outside under the bumper and it comes off.
trdkamuri51o
Postby 1st Gen Sol » Mon May 09, 2005 9:07 pm
trdkamuri51o wrote:6 bolts remove the plastic panels on the inside of the trunk and u should see them run along the edge. i think 10mm remove them and the plastic clip on the outside under the bumper and it comes off.
^^^^ I had the same thing happen..........but I did what "trdkamurio51o" basically said to pop out the dent.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby xlxdarkmarinexlx » Sat May 14, 2005 12:07 am
One time someone backed into me, i made the mother f'er pay me 500 bucks cuz i got it estimated at a shop, i dont understand why you dont make the punks pay for things like that
Also fyi, the foam absorber may need to be replaced, if its smashed then it wont help you anymore, so you may need a new one.
Saepe Exertus, Semper Fidelis, Frater Infinitas Often Tested, Always Faithful, Brothers Forever
CPL*HUEY MWSS 473(-), MAG 47, 4th MAW
www.myspace.com/nwhuey
xlxdarkmarinexlx
