SolaraGuy.com • View topic - Radio install
Radio install
Radio install
Postby tomlee » Fri Nov 29, 2002 12:09 am
I was installing my Kenwood KVT-910 DVD player into the car and I get a lot of engine noise. How do I get rid of it? Please help.
tomlee
Postby Gunman » Fri Nov 29, 2002 3:29 am
are you using off board amps or off the hide away brain?
Gunman
Postby Yanks0114 » Sat Nov 30, 2002 11:57 am
Sounds like you have a grounding problem. I had that trouble on my neon pedals, just check your ground. It could also be RF interference from engine mods, usually from spark plug wires, but even the magnecor wires don't emit an interference. Please post in more detail
Postby Guest » Sat Nov 30, 2002 1:36 pm
Are you getting alternator whine or a buzzing noise. Buzzing or clicking noise is plug wires. Where did u ground the radio. I have aftermarket radio in my 96 Camry and its perfectly quiet.
Guest
Postby Gunman » Sat Nov 30, 2002 9:18 pm
i just did a 911 the other day, and you should have both ground wires connected, where is the brain mounted?
Gunman
Users browsing this forum: Google [Bot] and 22 guests
