SolaraGuy.com • View topic - Flipside, I have a question
Postby Guest » Fri Nov 29, 2002 6:16 pm
Hey,
I recently sold my 3in1 single CD/Cassette and radio player along with JBL amp to someone with 95 Camry... Now he tells me my stereo doesn't work..
Is this a competibility problem? Can you use 99 Solara JBL system (amp) with 95 Camry?
Thanks
Jay
Guest
Postby Jay » Fri Nov 29, 2002 6:16 pm
That was me... :)
Jay
Re: Flipside, I have a question
Postby ultramookie » Fri Nov 29, 2002 6:53 pm
Anonymous wrote:I recently sold my 3in1 single CD/Cassette and radio player along with JBL amp to someone with 95 Camry... Now he tells me my stereo doesn't work..
Isn't there some sort of security thingie with the systems in the Solaras? Like it's coded or something...
ultramookie
the guy pulling all the levers
Postby Jay » Sat Nov 30, 2002 7:42 pm
Does anybody know more about this security feature? I've heard of it, but I don't know which cars are affected..
Jay
Postby Luc » Sat Nov 30, 2002 8:39 pm
There are no security features on any of the 3-in-1s within the Gen4 and Solara. If his '95 didn't have the premium system, then the factory plugs are incompatible with the 3-in-1, with or without the JBL amp. It's more like a compatibility problem.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Postby Gunman » Sat Nov 30, 2002 9:16 pm
you should be able to use it, you have to give him the amp though, he can use the one that came with those models, the older amps are right under the radio a bit or under the passenger seat, i know it works, i did it for someone already.
Gunman
Postby Yanks0114 » Sat Nov 30, 2002 11:32 pm
The solara does not have the security code on the headunit. This mainly occurs in GM cars, and is such a pain. My friend has a 2000 Grand Am GT and his battery went dead and the radio went into lockdown. The dealer wanted to charge $88 just to enter in the code, and it could happen again
Postby Missay » Sat Nov 30, 2002 11:49 pm
i remember land rovers used to always need the radio codes. the dealer should give it to you for free. some would give it over the phone w/ the last 8of the vin, but others required you to go to the dealr w/ your registration and proof of ownership. that's hgwy robbery chargin you for a radio code. most places will give it to you when you buy the car (at least land rover did, but most owners misplaced it or lost it after a couple of years)
Melissa
Missay
SolaraGuy Ambassador
Postby Yanks0114 » Sat Nov 30, 2002 11:56 pm
Personally i think its absolutely rediculous. No one would want a stock radio, and if they did it probally wouldn't fit. Its much easier to target an aftermarket headunit, especially because if they stole my stock headunit, it has no amp in it, the JBL amp in behind the glovebox
Postby Flipside909 » Sun Dec 01, 2002 2:13 am
Anonymous wrote:Hey,
Yes it is. But if the guy has time to work the wiring, he could actually get it to work by cutting and splicing the wires...but you have to know what you are doing exactly to make it work. It's usually too much work for something OEM and it probably would be better to spend that money on a more powerful aftermarket system.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jay » Sun Dec 01, 2002 2:38 pm
Gunman wrote:you should be able to use it, you have to give him the amp though, he can use the one that came with those models, the older amps are right under the radio a bit or under the passenger seat, i know it works, i did it for someone already.
You mean you installed 99+ stereo and amp to 95 or older camry?
Flip says it's not possible..(read the post above).
Jay
