SolaraGuy.com • View topic - Lights dimming
Lights dimming
Lights dimming
Postby 00-solara » Fri May 13, 2005 8:30 pm
I have a 4-cylinder and with my kicker 10 L7 and a 400.1 amp cranked up it dims is this bad or can I do something about it beside get a new alternator. Or is that my only choice?
2000 Solara SE Diamond White Pearl: 4300K HIDs, Sony H/U, Infinity Kappa 60.5, 693.5i, Two Kicker CVX 10"
00-solara
Re: Lights dimming
Postby SpeedSTARs » Fri May 13, 2005 8:38 pm
00-solara wrote:I have a 4-cylinder and with my kicker 10 L7 and a 400.1 amp cranked up it dims is this bad or can I do something about it beside get a new alternator. Or is that my only choice?
I think you other option would be to either run a higher powered alternator by Stinger or something. Or option 2, to run a 1 farad capacitor and a Deep cycle Yellow top Optima battery with earth grounds. This helped me get rid of the dimming lights when the bass note hit a low. Anyway, hope this helps you out. :wink: :D
SpeedSTARs
Postby Jon11582 » Fri May 13, 2005 9:38 pm
I think a half farad cap OR the yellow top will be good enough to keep it from dimming with only a 400w sub.
2000 Black Solara SE
Jon11582
Postby SpeedSTARs » Fri May 13, 2005 11:37 pm
I just remembered, don't forget to run the 4 gauge wire and fuse link. The 8 gauge is sufficent; however, the 4 gauge will give you more room to grow you system. :wink: :D Jon11582 has a good point. :P
SpeedSTARs
Postby SleeperSolara » Sat May 14, 2005 8:39 am
Yeah a 0.5 farad cap should be more than enough.
If you have the money then all out wit yellow top battery, and stronger alternator, wit a 0.5 farad.
Also use 4 gauge for more effience power, and also to grow the system if you want to
Postby 1st Gen Sol » Sat May 14, 2005 10:38 am
Infared cap..........distribution block........and a Optima Yellow top battery........should take care of your problem.
Haven't been into the audio scene for awhile but thas what I always made sure I had.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby 00-solara » Sat May 14, 2005 9:44 pm
how much for capacitor and what size is stock to what should I get?
00-solara
Postby SpeedSTARs » Sat May 14, 2005 9:55 pm
00-solara wrote:how much for capacitor and what size is stock to what should I get?
Hey Bro,
There are two sites you might want to look into.
This site has the .5 farad capacitor:
http://www.crutchfield.com/S-hFIcGq4PTCD/cgi-bin/ProdGroup.asp?g=725&avf=N
However, The site Techronis.com is listing a 1 farad cap for less than a .5 cap listed at Crutchfield. Here you go:
http://www.techronics.com/index.cfm?fuseaction=category.display&category_ID=12&mfg_account_ID=&sort=low
Hope this helps out. Maybe the other guys have better listings??? Cause we never turn our backs on a SolaraGuy brother... Anyway good luck. :wink: 8)
-G
SpeedSTARs
Postby Turbosolara » Sat May 14, 2005 11:52 pm
with a capacitor you wont have problem. you dont have to change your alternator.
Postby 1st Gen Sol » Sun May 15, 2005 10:11 pm
I forgot.....I got a brand new .5 Lightening cap that I never used if you are looking for one.....send me a private messege with a reasonable offer if your interested.
1st Gen Sol
Stock Sleeper
Stock Sleeper
