SolaraGuy.com • View topic - Fixed my brake squeel!!
Postby xavier » Mon May 16, 2005 5:36 am
I finally figured it out. I noticed unusual edge wear on the wear surface of the pads. I looked on the rotor and on the inner and outer edges, there are small raised "lips". The brake pad surface doesnt actually cover the entire rotor so rust forms on the face that is not in contact with the pads. This raised rust would barely rub on the pads causing an irritating whine at half brake. The noise would go away at full brake. The *RIGHT* fix: have your rotors turned or even take some sand paper and sand down the lips on the rotor. *MY* fix (not the right way): use a grinder and grind a small beveled edge on the face of the pad. The edges will be beveled enough to not touch the rusty lip. There is no noticeable brake fade or anything. My brakes feel no different because the difference in the amount of pad touching the rotor is minimal. The result is quiet brakes!
xavier
Postby 1st Gen Sol » Mon May 16, 2005 9:24 am
Thanks for the info.....I wonder if this would apply to my 95 Avalon b/c the rear brakes squeak like crazy when I back up in the mornings..............
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby xavier » Mon May 16, 2005 10:53 am
^ that might just be the pads rubbing the rust off. If the noise goes away, I wouldnt worry about it but if it doesnt go away....this might fix it.
xavier
