SolaraGuy.com • View topic - Brake "sliding" noise.
Postby KRNguyW/aSOLARA » Mon May 23, 2005 11:21 am
As im braking and RIGHT about to come to a complete stop, i hear this noise coming from the front of the car (sounds like its coming from somewhere underneath) it makes this sliding noise. As if somethings stuck there or like something is shifting forward. Anyway have any ideas? Also it SEEMS to be worse with more people in the car (thats when i really notice it). Thanks.
RED '99 SE V6 5-SPD--STOCK (at the moment)
KRNguyW/aSOLARA
Postby xavier » Mon May 23, 2005 11:54 am
Might wanna check the pads to make sure the pad ear tensioner things are there. The part of the caliper that the pad ears fits in is bigger than the pad ears so if the soft metal tensioner isn't there, the pads might shift around in the caliper. I dont think its bad....just noisy
xavier
Postby WTF?? » Mon May 23, 2005 12:33 pm
pads eating into your rotors? :o
Retired... its been fun Image
WTF??
Postby SpeedSTARs » Mon May 23, 2005 12:43 pm
Hopefuly its not the sliding pilot pin on the caliper. I had one of those seeze up on me on the driver side :( . In other words the driver side pads weared faster than the passenger side. Good luck dude. :P
SpeedSTARs
Postby 1st Gen Sol » Mon May 23, 2005 1:28 pm
Might be your brake pads wearing away and possibly now your rubbing metal against metal ? ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby KRNguyW/aSOLARA » Mon May 23, 2005 4:09 pm
crap. how much will it eff up the rotors if i dont replace my pads RIGHT AWAY? cuz well, its been doing that for about a week on and off. i hope its not those other things some of you guys mentioned..since i dont know what those are =D thanks though. i'll take a look at my pads i guess.
KRNguyW/aSOLARA
Postby trdkamuri51o » Mon May 23, 2005 4:28 pm
just replace the pads and rotors at the same time. if your goig metal to metal it will make more of a scraping sound. throughout braking. take a look at the rotor does it have SIGNIFIGANT grooves like it was being eaten away???
hell hit me up this weekend ill help you out dude.
trdkamuri51o
Postby 1st Gen Sol » Mon May 23, 2005 5:30 pm
It shouldn't be that bad if its only a week, I've know people that have driven like that for longer periods of time but to be on the safe side, just get the brake pads and rotors........but have your mechanic check it out first to make sure that, that is the problem and your not spending cash on something you don't need.........
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby KRNguyW/aSOLARA » Mon May 23, 2005 10:24 pm
lol.. new rotors are too deep... cant afford man. HOPEFULLY, my rotors arent jacked.. Should i brake softer?
KRNguyW/aSOLARA
Postby xavier » Tue May 24, 2005 5:06 am
If your pads are done....your stopping with the rivets so softer braking will just make you more likely to hit the guy in front og you. Just look through the wheel and see if you see gouges in the rotor. I doubt it is your rotor being ground because you WILL KNOW if thats happening. You hear it and feel it in the pedal
xavier
Postby KRNguyW/aSOLARA » Tue May 24, 2005 4:35 pm
xavier wrote:If your pads are done....your stopping with the rivets so softer braking will just make you more likely to hit the guy in front og you. Just look through the wheel and see if you see gouges in the rotor. I doubt it is your rotor being ground because you WILL KNOW if thats happening. You hear it and feel it in the pedal
i see. well thats good cuz i here absolutely NOTHING coming from my brakes. but they do shake when im braking at around 60mph (people said they were probably warped) so hopefully its just the pads.
KRNguyW/aSOLARA
Postby radio2lady » Sun May 29, 2005 6:43 pm
I thought I would tell you about this weird noise that has been going on with my brakes for about a month now. When I apply the brake there is this "aaaaaahhhhhh" noise from the petal. It comes and goes and sounds like a whisper or just an air noise. I took it in to have the brakes checked because no warning light came on but I never had this noise before. Toyota checked it out and I was a bit concerned when the mechanic came in to talk with me. Yipes! This can't be good. He explained abit how the brakes worked and then told me about the brake power booster. Bottom line is $1150 installed! He said mine is not broken but he dosen't know why I am getting the noise. Guess when it goes out I have to stand on the brake, it acts as if I have no "power" brakes. Can't wait till that happens! Then the mechanic hands me his card with his cell phone number and tells me if I want to sell my car, call him, his daughter is dying for a Solara like mine. He also gave me lots of complements on my care of the car. Thank you Zaino! Love that stuff.
radio2lady
Postby trdkamuri51o » Sun May 29, 2005 10:23 pm
lol radio.... ever hear of a scare tactic????
trdkamuri51o
Postby so-cal_sol » Sun May 29, 2005 10:34 pm
lol, dude take it to a regular shop and then have them check it out. the guy at toyota want to charge you an s-load of money for something that would be cheaper at some other shop. they could probably order toyota parts and charge you less for labor.
2005 lunar mist metallic se V6
Trenz Grill
Eclipse 2454 HU
TRD springs *DROPT BY MILT*
so-cal_sol
Postby trdkamuri51o » Sun May 29, 2005 10:37 pm
jon come over tommrow bring me some baskin robins and ill do all the work for ya :lol:
trdkamuri51o
