SolaraGuy.com • View topic - dumbasses
dumbasses
dumbasses
Postby RichD978 » Wed May 25, 2005 12:31 pm
some dumbass left one of those 5 lb dumbells on the road and i couldn't avoid it cause i wouldve caused a car accident . I was forced to run over it... Well all i heard was kadonk kadonk kadonk underneath my car... I was going around 30-40mph. Is there any damage I should be concerned about? What should I check for ? Thanks guys
RichD978
Postby SpeedSTARs » Wed May 25, 2005 12:39 pm
Hey Bro,
I'd check the undercarrage and the rocker panels for damage (TRD body kit etc.). Hopefuly everythings alright. :angel:
SpeedSTARs
Postby RichD978 » Wed May 25, 2005 12:41 pm
you think i would have any mechanical damage? I care about that mroe than physical damage
RichD978
Postby SpeedSTARs » Wed May 25, 2005 12:45 pm
If anything mechanical, I'd say the front sway-bar (if its bent). The control arm linkage in the suspenion. Or even the brake or fuel lines if there bent or kinked. :angel:
SpeedSTARs
Postby RichD978 » Wed May 25, 2005 12:47 pm
how can i check those myself w/o lifting the car or anything? i have no time and money. can i check while driving (fsb & brakes)
RichD978
Postby SpeedSTARs » Wed May 25, 2005 1:06 pm
If you don't mind getting dirt on your knees, then the way to check would be to turn the steering wheel to the point where u can see the FSB for damages. The Fuel lines (that might be in the area of impact) you'll need to place on ramps or jack the car up (with of course chalked back wheels to keep from rolling (use big enough piece of wood)). The worry would be just to check if there is any gas leaks. Hopefully not. :angel:
SpeedSTARs
Postby RichD978 » Wed May 25, 2005 1:10 pm
but its raining like crazy. Would it be safe to drive?
RichD978
Postby SpeedSTARs » Wed May 25, 2005 1:14 pm
SpeedSTARs wrote:If you don't mind getting dirt on your knees, then the way to check would be to turn the steering wheel to the point where u can see the FSB for damages. The Fuel lines (that might be in the area of impact) you'll need to place on ramps or jack the car up (with of course chalked back wheels to keep from rolling (use big enough piece of wood)). The worry would be just to check if there is any gas leaks. Hopefully not. :angel:
If your driving, then check if your hearing any kind of baming, clunking, grinding noises or clanging from any of the areas of the front end (make sure the radio and AC/ climate control s turned off). The second area of concern would be to listen for noise when your turning the steering wheel (this is to check if CV-boot joint is still good-other wise if there is grinding sounds the joint could be damaged) :angel:
SpeedSTARs
Postby SpeedSTARs » Wed May 25, 2005 1:16 pm
RichD978 wrote:but its raining like crazy. Would it be safe to drive?
If your steering and brakes work fine (if there is no fluid leaks-gas or brake fluid), then yes its safe to drive... :angel:
SpeedSTARs
Postby thealkimo » Wed May 25, 2005 1:22 pm
aw man dude that sucks...
good luck and hopefully everything is okay...
atleast there wasn't an accident...
thealkimo
Postby ultramookie » Wed May 25, 2005 1:25 pm
That sucks, I had a similar experience a while back (had a huge piece of engine in the middle of the freeway, went over it at like 65MPH). For me, the car was already acting funny after I ran that stuff over (the engine made weird noises and didn't run right). So, I took it to the dealer to have it looked at. I had damage to the headers, suspension, muffler and some other stuff under there. I think if the car runs OK, maybe you should take it to a dealer or someone to take a good look at the underside of the car.
ultramookie
the guy pulling all the levers
Postby SpeedSTARs » Wed May 25, 2005 1:32 pm
^^^ Well say ultramookie... Let the professional (dealer or a trusty garage you go to) take a look at it. Again, Sorry to hear your misfortune. :angel:
SpeedSTARs
Postby michaels artic frost » Wed May 25, 2005 1:34 pm
Dang Rich...hope nothing's wrong bro.
Updated 06/01/12: Michael T's
Postby Hsakuragi » Wed May 25, 2005 1:40 pm
jack up the car and check, espically ur oil and trans pan
Hsakuragi
Postby that1mexguy » Wed May 25, 2005 1:50 pm
yeah man, take it to a shop and have it inspected... do not risk it. If some major damage was done, i think ur insurance could cover it under your comprehensive coverage. I've used my insurance for when my car was keyed (all the way around - bastards), and recently when a rock chipped my windshield. (all i pay is my deductible which is $50 :D) and it doesnt increase my premium. Of course, I dont know what type of insurance you have but it wouldnt hurt to call them and ask.
that1mexguy
Users browsing this forum: Google [Bot] and 38 guests
