SolaraGuy.com • View topic - JBL amp underneath the glovebox?
Postby impactX » Mon Dec 02, 2002 4:52 pm
Well, we all know what the headunit is like. To my surprise, when I take out the glove compartment to do some wiring for the sub, I see that there's a JBL unit there. I am wondering what the heck is that... If that is an amp, that means the cd player has preamp out? If the cd player doesn't have preamp output, then what is that JBL unit???
BTW it's a 2000 Solara with this cd player:
impactX
Re: JBL amp underneath the glovebox?
Postby Yanks0114 » Mon Dec 02, 2002 4:58 pm
impactX wrote:Well, we all know what the headunit is like. To my surprise, when I take out the glove compartment to do some wiring for the sub, I see that there's a JBL unit there. I am wondering what the heck is that... If that is an amp, that means the cd player has preamp out? If the cd player doesn't have preamp output, then what is that JBL unit???
That unit that u have displayed is just a control panel. The amp is where the power comes from. Its not really a preamp out. Are you trying to hook up subs?
Postby Guest » Mon Dec 02, 2002 5:09 pm
but the new JBL in dash 6 CD player has the amp in the head-unit right?
Guest
Postby Flipside909 » Mon Dec 02, 2002 5:49 pm
Anonymous wrote:but the new JBL in dash 6 CD player has the amp in the head-unit right?
Nope. External amp like the single disc player.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Gunman » Mon Dec 02, 2002 9:06 pm
what is it that your trying to do? are you keeping the factory head?
Gunman
Postby impactX » Tue Dec 03, 2002 5:23 am
Gunman wrote:what is it that your trying to do? are you keeping the factory head?
What I am trying to do is... replace the head unit.
I already hooked up the sub using speaker level input on the amp.
If I replace the head unit, I will have to remove that JBL external amp then?
What if I get a wiring harness for Solara, where will I connect the harness to from the head unit? This is giving me a headache.
impactX
Postby Gunman » Tue Dec 03, 2002 6:22 am
ok if your replacing the head unit, it should have preout(sub or mono is preferable) and you can use the normal harness, it double back to a normal harness up to the right behind the head unit, switching the head is really pretty simple. if you have any more questions or problems you can leave me a message.
Gunman
