SolaraGuy.com • View topic - How do i remove fog light Bulbs
Postby Yanks0114 » Mon Dec 02, 2002 4:59 pm
I just received my new fog light bulbs, super white. I was looking at the fogs and i have no clue how to remove the bulbs. Can anyone help?
Postby NASTY » Mon Dec 02, 2002 5:46 pm
think the manual should tell you...did you check there?
'01 SLE V6
NASTY
Re: How do i remove fog light Bulbs
Postby Flipside909 » Mon Dec 02, 2002 5:48 pm
yanks0114 wrote:I just received my new fog light bulbs, super white. I was looking at the fogs and i have no clue how to remove the bulbs. Can anyone help?
You have to remove/unbolt the splash guards under the bumper...then reach in, unclip the holder, unplug the harness, and pull out the bulb. That's the condensed version. The owners manual lists everything in detail.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Mon Dec 02, 2002 5:55 pm
sweet, it worked. Thanks guys
Postby Flipside909 » Mon Dec 02, 2002 5:58 pm
Anytime. :)
www.clublexus.com
Flipside909
Postby eyedea » Mon Dec 02, 2002 8:55 pm
Flip..it took me abt 2 days trying to figure out how to change my fogs but when i did, thats the exact method i used.
5SP 02 SE V6 SC 1MZFE .......RIP ...
2003 Infiniti M45 =340hp of RWD sex
eyedea
Postby Missay » Mon Dec 02, 2002 9:52 pm
when you say harness, is it basically the same set up as the headlights? you disconnect the wire, take of the rubber thing, unclip the harness thing, replace the bulb, then put it back together?? i think i know how to do the splash guard thing cause i watched the body shop take it off when they checked my windshield washer reservior...i forget what tool he used to remove the bolts tho?
Melissa
Missay
SolaraGuy Ambassador
Postby Blaze » Mon Dec 02, 2002 10:15 pm
normal wrench
Blaze
Postby Flipside909 » Mon Dec 02, 2002 11:07 pm
2 days? Dang...were you doing it in the dark? placing the bulbs into the assembly was somewhat tough considering you have to match up the notches together.
www.clublexus.com
Flipside909
Postby eyedea » Tue Dec 03, 2002 12:58 am
I am sucha dumbo when it comes to cars. I looked everywhere even under the hood and even tried to squeeze my hand in between the headlights to access the fogs. I had basically given up till i had a bulb flashing in my head to try it from underneath. At least i admit i am a dumbo..i aint like gunman you know. I love plug and play.
eyedea
