SolaraGuy.com • View topic - Need help~!! Sunroof stuck~!!
Postby socalisolara » Sat May 28, 2005 1:15 am
i dont know if this is a major problem, but today for the 1st time my sunroof got stuck. There was a huge thud when opening and it just got stucked.. how can i fix this...?
socalisolara
Postby SleeperSolara » Sat May 28, 2005 8:49 am
Is it stuck on tilt??
If that the case that should be ok, unless it rainin'.
You can probably go to dealership to get it fixed.
Postby sleepin2000 » Sat May 28, 2005 12:15 pm
Mine has done the same thing a couple of times but it always seems to fix itself. Hopefully yours will do the same.
In Memory of My Son
Christian Edward Goldstone
October 13, 2005 - June 7, 2007
sleepin2000
Postby Jetfixer » Sun May 29, 2005 4:39 pm
Mine was doing that for a long time. There are two adjusting screws on each side. You have to pull off the thin black plastic strips that hide them. You'll need a torx bit (#25 I think) Mine was hanging up after trying to close it from the tilted up position. I ran it right to the point where it was hanging up, and then loosened the adjusting screws about a half turn each and pushed the glass panel forward, then tightened them. Also, I found a lot of gunk in the tracks, especially packed into the forward edges. After this adjustment and cleaning, mine works like new.
Jetfixer
