SolaraGuy.com • View topic - Disablin' DRL's didn't work
Postby SleeperSolara » Fri Jun 03, 2005 2:45 pm
Ok here's the deal.
I've read http://www.solaraguy.org/viewtopic.php?t=8530 thread.
And also went to: http://www.legacytuning.com/DRL/DRLdisable.htm
And read the site, and tried the the diagram:Image
And took out the 23rd wire which is the black wire, from the bottom row from the left, wit the flat part of the "U" and taped the wire off wit electric tape.
But the DRL's are still turnin' on.
Which wire color is the one for the DRL??
I've takin' out the white wire wit the stripe, and that didn't work.
Also tried the red wit red stripe, and that didn't work either.
So anyone that has done this??
Which wire color is it??
Postby 1st Gen Sol » Fri Jun 03, 2005 4:45 pm
I didn't cut or remove any wires when I disabled my DRL's.
All I did was unplug the sensor harness under the hood on the passenger side behind the strut tower brace. You can't miss the plug, only big gray plug in that location.
After I unplugged that, my day running lights were disabled...........they only turn on by themselves at night when its pitch black dark out.
........unless your looking to totally disconnect it where you have to turn it on at night...........
hope my two cents was of some help bro.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby boneezy » Sat Jun 04, 2005 12:07 am
yeah, disconnect that gray connector for the drl's under the hood. then pop up the twilight sensor and disconnect taht if you want to to toatlly disable the whole drl system
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby that1mexguy » Sat Jun 04, 2005 6:26 am
yup yup, i disconnected that connector and i also unplugged the sensor on the dash (on your passenger's side), that should do it man
that1mexguy
Postby SleeperSolara » Sat Jun 04, 2005 10:14 am
Yeah i know about the plug under the hood near the passenger side.
And the eye thingy in the car near the passenger side on the dash
Postby pythonjosh » Sat Jun 04, 2005 11:16 am
So did unplugging the gray wire harness work? It did for me.
pythonjosh
Postby toy4x4boy » Sat Jun 04, 2005 5:47 pm
Unplugging the gray connector worked for me too!
toy4x4boy
Postby dominoSLEV6 » Sun Jun 05, 2005 12:43 pm
I did the 23rd wite disconnect for my DRLs today and it worked just fine.
I guess I didn't make note of the fact that unplugging the grey plug does the same thing?
My question is this: does unplugging the grey plug by the firewall disable the night time sentinel lights?
Or do I have to do something else?
-chris
dominoSLEV6
Postby SleeperSolara » Sun Jun 05, 2005 5:05 pm
Nope for my 2000 the black wire near the ign for the DRL relay, is for the e-brake light on the dash.
Really don't want to unplug the grey plug under the hood cause dirt and shittee could get in there.
I know that i can tape it up but enigne bay would look unclean look
Postby dominoSLEV6 » Sun Jun 05, 2005 7:16 pm
Actually I found out tonight that cuttign the 23rd wire disabled my nighttime automatics AND my DRL's.
I have a '99 SLE.
It worked for me so I'm happy, it took about an hour cause it so damn tight with space and penels poking you all over the place down there, plus I did it withotu removing the center dash part, which I would highly recommend to anyone planning on doing it. I just didn't know how to and didn't feel like doing it.
It was funny cause I had my battery disconnected and then when I wanted to put my seat down to lay backwards and upside down there was no power to it obviously so I did the whole thing in a reverse chair type position... I'm sure I looked alike a dumbass, but to me it was worth it to rid my beautiful car of those annoying automatic lights.
-chris
dominoSLEV6
Postby SleeperSolara » Mon Jun 06, 2005 2:42 pm
I just found out which one will work wit out unpluggin' the grey connector under the hood near the passenger side.
All you have to do is unplug the black lil relay in the "Relay & Fuses"; in front of the battery.
It should be the DRL Dim No. 4 relay.
That disabled the DRL while lookin' clean under the hood.
Cause when you take out the lil relay box thingy then puttin' the cover back on will cover it up. :D
Postby noodlerooney » Tue Jun 21, 2005 6:45 am
SleeperSolara wrote:I just found out which one will work wit out unpluggin' the grey connector under the hood near the passenger side.
For laughs, tried this, didn't work for me. In my car, the DRL Dim No. 4 relay was a reddish color, not black. Tried the red then black relays, couldn't get it to work. Anyone else get this to work?
15,001 miles, Garage Queen
noodlerooney
Postby SleeperSolara » Tue Jun 21, 2005 10:02 am
What Gen you have??
Gen 1 there will be a box thingy in front of the battery.
Then you open that and will see the relay it will be really big, it on the left.
That should disable it.
Postby noodlerooney » Wed Jun 22, 2005 7:12 am
As my sig indicates, I have a 2000 SLE, Gen 1 I think. I did find 2 relays in that "box thingy" in front of the battery, one reddish the other black, however, the DRL Dim No. 4 relay on the left was a reddish color, not black. Tried removing the red then black relay, still would not work. It did, however, disable my headlights. After examining the electrical wiring diagrams, I don't see how this could work. Maybe if I can post a picture/diagram of what I have. Anyone else get this to work or have the same configuration as I am talking about?
noodlerooney
Postby Paladin06Greg » Wed Jun 22, 2005 7:24 am
I'm a little confused as to why you would want to disconnect your DRL's..
Paladin06Greg
Torqued Solara
Torqued Solara
