SolaraGuy.com • View topic - Help! Fans aint working.
Postby methyl mike » Tue Jun 07, 2005 5:21 pm
Hey guys my check engine light is on, and I noticed my engine fans dont work, any ideas? I checked the 2 boxy fuses in the engine compartment listed in my owners manual, and theyre both fine. Help?
methyl mike
Postby Turbosolara » Tue Jun 07, 2005 11:20 pm
the engine fan would only spin when the temperature is up. if you unplug the coolant sensor wire (at the bottom of the radiator), it will force the fan to spinl. also if your fan is broken it is NOT relate to check engine light. you need to get the trouble code and we can assist you further
Postby methyl mike » Wed Jun 08, 2005 11:02 am
Ok ill get that code for you. Thanks!
methyl mike
