SolaraGuy.com • View topic - toyota red coolant not recommended?
Postby JAYDEE23 » Fri Jun 24, 2005 4:48 pm
i came across this site that strongly recommends switching to prestone as soon as the warranty runs out
"The Toyota red coolant on the other hand seems to age just as fast as the old style coolant, is impossible to litmus test (because of the red dye), and seems to generate a lot of radiator clogging residue. We recommend removing the Toyota coolant and installing Prestone as soon as the warranty expires. "
can anyone back this up? i have to flush the radiator soon and im having a hard time finding red other than a toyota dealer which is a pain to drive to.
http://www.artsautomotive.com/coolingstory.htm
JAYDEE23
Postby so-cal_sol » Fri Jun 24, 2005 4:51 pm
um.... really???
2005 lunar mist metallic se V6
Trenz Grill
Eclipse 2454 HU
TRD springs *DROPT BY MILT*
so-cal_sol
Postby krawzyazn » Fri Jun 24, 2005 4:53 pm
hell no lol
Postby jsie » Fri Jun 24, 2005 5:05 pm
Actually I read some where else in the Internet that the Toyota red is the best out there. Unfortunately I lost the link; I'll post it here when i found it back. Anyway, newer Toyota is now prefilled with the "Super" Long Life (90k-100K interval) vs the Long life (45k interval). The "Super" Long life is still hard to find, but I have seen one of the Toyota dealer here carries them. I know for sure the Gen 2 Solara is pre-filled with the "Super" Long life. When the time come for radiator flush for my car, I will put in the "Super" long life.
2004 Solara SE Sport
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Re: toyota red coolant not recommended?
Postby bronzemaxell » Fri Jun 24, 2005 6:25 pm
JAYDEE23 wrote:i came across this site that strongly recommends switching to prestone as soon as the warantee runs out
that link sound more like marketing for their service
the toyota manual states that toyota red coolant was designed to lubricate water pump and minimized alloy engine rust on 1mz-fe v6 engines as well.
bronzemaxell
Postby Turbosolara » Fri Jun 24, 2005 7:16 pm
i am not sure, but i am sure toyota R&Ds are not idiot. also, herhap it will clog, but for sure it prolong water pump life. My solara has 70000 miles with turbo, and my red coolant still show bright red color. unlike the green coolant, turn darker over time.
Postby JAYDEE23 » Sat Jun 25, 2005 5:55 am
yeah from everything i read on this forum seems like red is the way to go..
i read through their site a bit and they seem like a good buisiness.
if "good for all newer cars" prestone is indeed no good for our toyotas i find it odd they would know this
mabey i will email them and see what they say about the waterpump deal.
JAYDEE23
Postby Jackass-Jeff » Sat Jun 25, 2005 6:09 am
It's almost like the Honda Auto Trans Fluid (ATF) thing... you CANNOT put non-Honda ATF in or the Trans will shift even worse than it already is!
Use the red or pink Toyota fluid ONLY. The service interval is the same (materials in the radiator) so you can use either fluid. I heard most are stocking PINK only now. (Pink is the new coolant.) Your first PINK coolant change is at 100K... and 50K after that. Obviously not for our cars, but for the newer cars (04+ Lexusss)
1GR-FE ftw!
Jackass-Jeff
Postby Paladin06Greg » Sat Jun 25, 2005 7:36 am
In addition, it is important to keep in mind that there is additive in the Toyota RED coolant that is required to prolong the Toyota water pump life and lubricate its seal. This additive is not present in the GREEN coolants and will cause premature Toyota water pump failure. My source, Toyota.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Sat Jun 25, 2005 8:58 am
Learned from uncle.
He told that when he had green coolant; he had to replace every 6 months or so.
So he changed to Toyota Red and didn't have any problems.
Then he sold his car for a Land Cruiser and now rollin' in a Tundra.
I changed mine to Toyota Red, and no problems.
Postby Grnarowana » Sun Jun 26, 2005 4:48 pm
Isn't red coolant better for sport cars? and green for wutever else cars?
I dunno, i'll do red just because it's totally unique to other cars.
Grnarowana
Postby Jai_Jai_Binks » Mon Jun 27, 2005 8:14 am
back in the day i used to roll on prestone GM dexcool (it was orangish color). But then there was some recall for that coolant (back in the day), and apparently GM cars were overheating. Since i heard that, i was bound to never use something that 'could' harm my car. Glad my solara has only seen red coolant.
Postby bassthrive » Mon Jun 27, 2005 9:12 am
I am running prestone right now and it is RED.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby JAYDEE23 » Mon Jun 27, 2005 10:47 am
red prestone huh? wonder if this is compatible w/ our cars. Does color represent some unnown (to me anyway) antifreeze/coolant language?
JAYDEE23
Postby bassthrive » Mon Jun 27, 2005 2:02 pm
its actually prestone orange, but it looks red in the reservior.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
