SolaraGuy.com • View topic - Check Engine Light Update*****
Postby 99SEAUTO » Sat Jun 25, 2005 10:18 am
Well after checking the code(1410) It gave us 3 possible problems and ofcourse with my luck it came out to be the last problem THE FKIN ECM
I dont even know how much that is going to cost me, but yah anyone had to replace the ecm?>
99 SE V6
99SEAUTO
Postby ~Spadwaller~ » Sat Jun 25, 2005 10:23 am
I have no idea how to replace the ECM but they are on ebay all the time for fairly cheap. good luck bro
~Spadwaller~
Re: Check Engine Light Update*****
Postby Paladin06Greg » Sat Jun 25, 2005 10:28 am
Your ecm is under the kick plate on your passenger side. Two screws/bolts and a couple electrical connectors. It's piece of cake. 15 20 minutes remove/install tops!!
99SEAUTO wrote:Well after checking the code(1410) It gave us 3 possible problems and ofcourse with my luck it came out to be the last problem THE FKIN ECM
Paladin06Greg
Torqued Solara
Torqued Solara
Postby 99SEAUTO » Sat Jun 25, 2005 11:08 am
does anyone know how much a new ecm goes for?
99 SE V6
99SEAUTO
Postby Jackass-Jeff » Sat Jun 25, 2005 11:25 am
99SEAUTO wrote:does anyone know how much a new ecm goes for?
$1000 or so + you return your broken one (called a CORE CHARGE)
1GR-FE ftw!
Jackass-Jeff
Postby 99SEAUTO » Sat Jun 25, 2005 11:12 pm
ehh found one on ebay for 70.00
99 SE V6
99SEAUTO
Postby Turbosolara » Sat Jun 25, 2005 11:47 pm
surprise me it is actually ecm problem, well it is plug and play very easy to fix. just make sure dont get the california version, it is tuned a bit differently i believe.
