SolaraGuy.com • View topic - Shifting is not smooth anymore?
Postby redsolara » Wed Dec 11, 2002 4:39 pm
I have a standard solara i bought in 2000 brand new, ever since like the last 6 months my shifting is really stiff, i mean i push it in first gear and it wont take it, i have the clutch pushed all the way in, and some times when i down shift it's hard and stiff too, i just miss the smooth shift times, maybee i need some work or adjustments??? Some times i have to try like three time to put it in reverse too, it kind of sucks, the car runs fine dispite this shift stiffness problem...
Red Solara*Red Solara*Red Solara*Red Solara
redsolara
Re: Shifting is not smooth anymore?
Postby Yanks0114 » Wed Dec 11, 2002 4:46 pm
redsolara wrote:I have a standard solara i bought in 2000 brand new, ever since like the last 6 months my shifting is really stiff, i mean i push it in first gear and it wont take it, i have the clutch pushed all the way in, and some times when i down shift it's hard and stiff too, i just miss the smooth shift times, maybee i need some work or adjustments??? Some times i have to try like three time to put it in reverse too, it kind of sucks, the car runs fine dispite this shift stiffness problem...
How many miles do you have on it and what are your driving habits? Could be your clutch. Are you the only one who drives this car, a clutch wears much quicker when many different people drive it.
Postby redsolara » Wed Dec 11, 2002 5:56 pm
i have 43,000 miles on it, and im the only one that drives it, i usually drive about 25 to 30 miles a day and 40 to 50 on weeknds. I only get oil changes done, ive never gotten anything else checked, well except about a year ago when i spent 120 dollars for the 15k mile check up with toyota, that sucked, they said everything was cool and basically did a visual inspection and topped all my fluids, any way... Im the only person that has been driving my car ever since i bought it.
redsolara
Postby Peter » Wed Dec 11, 2002 6:22 pm
i get the same thing.... i have 60k miles
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby 20SoLaRa02 » Thu Dec 12, 2002 12:07 am
i get the same thing and i have 10k...i've had it since i bought it....not sure if its the same as u. i'm beginning to wonder when the recall will be coming out?...lol
20SoLaRa02
Postby Peter » Thu Dec 12, 2002 12:14 am
i think all sticks are like this. my brothers cars are all like this also.
Visit Black Sheep
Peter
Postby Optimus » Thu Dec 12, 2002 12:25 am
All sticks are definitely not stiff (unless you meant all toyota sticks). Ever drive an Audi? Smooth..... almost a little too smooth.
the rough shift feel of the toyota stick is what kept me from getting one.
Peter - you have a TRD quickshifter, right? did that help any?
7 years w/ Gen 1 Solara....
Loved Toyota so much that I work for them now
Optimus
Postby cdssolara » Thu Dec 12, 2002 2:40 pm
Is this happening all the time, or just in certain situations? I have recently noticed difficulties getting into first gear after I have come to a stop and want to start up again. I also sometimes have problems getting out of 2nd gear when I come to a stop. Once I'm going, there doesn't seem to be a problem, although I've never found the shifting to be super smooth.
Anyway, in my situation I was advised to have the gears re-lubed. I haven't been able to get it done yet, but plan to in the near future. If all your gears are a problem for you, it could be a lube issue, but might be an indicator of bigger problems.
cdssolara
Postby Peter » Thu Dec 12, 2002 3:15 pm
Optimus wrote:All sticks are definitely not stiff (unless you meant all toyota sticks). Ever drive an Audi? Smooth..... almost a little too smooth.
no, the quickshifter actually makes it a little tougher.
Visit Black Sheep
Peter
Postby redsolara » Fri Dec 13, 2002 12:43 am
Yes, actually my gears do tend to tighting up after coming to a complete stop and throwing it back in first, and it does happen once a while but at least once a day, but after that the other gears are cool, but also sometimes when i push into third gear for some reason it wont take it, maybee i do need to lube it up...
redsolara
Postby Flipside909 » Fri Dec 13, 2002 2:28 am
Change your gear oil every 30k or more frequently if the shifting is rougher.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Fairlite » Fri Dec 13, 2002 8:40 am
redsolara wrote:i have 43,000 miles on it, and im the only one that drives it, i usually drive about 25 to 30 miles a day and 40 to 50 on weeknds. I only get oil changes done, ive never gotten anything else checked, well except about a year ago when i spent 120 dollars for the 15k mile check up with toyota, that sucked, they said everything was cool and basically did a visual inspection and topped all my fluids, any way... Im the only person that has been driving my car ever since i bought it.
There are things that should have been done at 30000, like change the Gear Fluid etc. I personally don't care what other people say about this but If you want to keep your car the way it was when you bought it, do all the recommened maintence. My car has NO trouble what so ever and I keep up with all scheduled Maint.
2000 Solara SLE
Toyo Proxies TPT
Alpine 7878 CD/MP3 Headunit, Alpine XM Radio, Alpine 6 Disc MP3 Changer, JL 300/4 & JL 500/1 Amplifiers, 2 Sets of Boston Pro 6.5 Speakers, Boston Pro 12.5LF Sub-Woofer.
Fairlite
Postby AZBRAT » Fri Dec 13, 2002 11:44 am
:roll: Mine is doing the same thing..... just in 1st and reverse. I'm getting the 30K tune-up tomorrow morning, I hope that helps. My 30K is $280, they better do more than just glance over it.
My s/c should be here any day now :D
'00 SE V6 MT
AZBRAT
Postby cdssolara » Fri Dec 13, 2002 3:37 pm
redsolara wrote:Yes, actually my gears do tend to tighting up after coming to a complete stop and throwing it back in first, and it does happen once a while but at least once a day, but after that the other gears are cool, but also sometimes when i push into third gear for some reason it wont take it, maybee i do need to lube it up...
Sounds like your situation is pretty similar to mine. I have the 3rd gear issue, as well, but I think that's just a notchy gear on our cars. It just isn't a smooth move into 3rd gear. I seem to have to hunt for the gate most of the time. Lubing will probably help, but I don't think it will solve that problem. Hopefully, it will solve the first and reverse difficulties, though. Let us know how it works if you get it done soon.
cdssolara
Users browsing this forum: Google [Bot] and 16 guests
