SolaraGuy.com • View topic - water injection cleans combustion chambers
Postby bassthrive » Wed Jul 20, 2005 12:59 pm
This is NOT for performance reasons, only maintenance. I have been doing some reading on combustion chamber cleaning and came across a mention that water misted into the intake will clean carbon and other gunk off the engines internals. Supposedly cleans even better than seafoam! Has anyone tried this? I have one of those portable atomizers that sprays an extremely fine mist to cool you down on a hot summer day.
http://www.se-r.net/about/200sx/scc/feb99/water_injection.html wrote:The super-heated steam also acts like a powerful steam cleaner inside of the engine, removing carbon deposits from inside the combustion chamber.
http://www.crash.net/uk/en/news_view.asp?cid=80&nid=98431&apn=3 wrote:as a beneficial side-effect your engine also gets a top-notch steam clean as the incredibly hot gas blasts away carbon deposits that stick to the interior surfaces and can be hot stops for abnormal combustion.
Plan to try this before the weekend along with my seafoam treatment. I would like to try misting directly into the TB but will the engine run if i remove the intake piping?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby StockSolara » Wed Jul 20, 2005 2:18 pm
The car might won't run if it doesn't sense any air going through the MAF Sensor
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
