SolaraGuy.com • View topic - Removing grille
Removing grille
Removing grille
Postby trioptimum » Sun Jul 24, 2005 10:48 pm
I can't get the freaking grille off. The 3 bolts aren't a problem, it's the clip or whatever on the bottom. How do I get it out of there? I've seen the post below, but it wasn't very helpful. I've stabbed and pried all over with a screwdriver on the bottom, nothing even hints at coming off. Anyone ever done it?! Tips? Thanks in advance ^^.
http://www.solaraguy.org/viewtopic.php?t=5345&highlight=remove+grille
________________________________
2005 Infiniti G35X AWD Sedan
1999 Toyota Camry Solara SLE V6
trioptimum
Postby ThatVietGuy » Sun Jul 24, 2005 11:32 pm
To take off my grill, I had to take off the bumper... although I had to take off the bumper anyway because I cracked it.
But when I had to take off the grill, it had to take a little force to pop it out of the holes. I also think you may have to move it side to side to get it loose.
ThatVietGuy
Postby thealkimo » Mon Jul 25, 2005 12:20 am
pull firmly...
just work it around a bit and it will eventually pop loose...
thealkimo
Postby SleeperSolara » Mon Jul 25, 2005 11:15 am
thealkimo wrote:pull firmly...
yeah use a flat head and pry it slowly on the bottom.
Takin' off the front bumper .............. not required.
Postby Jai_Jai_Binks » Mon Jul 25, 2005 12:13 pm
When looking at your solara headone, after remoing your three bolts, pull towards you (horizontally) don't pull up...(i know many moons ago i was ?? when i couldn't get it out trying to pull it upward)...pull it outward not upward!
Postby trioptimum » Mon Jul 25, 2005 12:16 pm
Cool, I've got to go change the downstream o2 sensor now (gotta put it on %&$#ing ramps) so I'll give the grille a try and hopefully get it out in one pice :). Thanks guys.
trioptimum
