SolaraGuy.com • View topic - battery problems
battery problems
battery problems
Postby lazyboyz69 » Tue Jul 26, 2005 12:55 am
well my car died 3 times on teh way home.... i had to jump start it 3 times..... it seems like if i go under 1k rpm the car dies.... i thinking its the battery... but it could be the alternator..... when i gas it the lights get stronger and the more electricty is uses the less power it has.... any suggestions?
lazyboyz69
Postby StockSolara » Tue Jul 26, 2005 1:54 am
It might be that your battery isn't holding a charge. . .
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby lazyboyz69 » Tue Jul 26, 2005 2:13 am
yea i was thinking that also.... i discconned the battery today....
lazyboyz69
Postby Ford_Fixorrepairdaily » Tue Jul 26, 2005 8:59 am
make sure the terminals are tight. My uncles camry kept dying becuase he didnt tighten the terminals. Just take your battery to pep boys or something and have them test it. If everything checks out with your battery then its something else. good luck
Postby ~Spadwaller~ » Tue Jul 26, 2005 9:13 am
It think its your supercharger better give it to me just in case :D
~Spadwaller~
Postby Jai_Jai_Binks » Tue Jul 26, 2005 9:22 am
lights getting faded with lower rpm's usually equates to an alternator problem, three times in one route back to home recharging is a lot. Get the battery checked, but my guess is still alternator.
Postby lazyboyz69 » Tue Jul 26, 2005 11:29 am
problem solved it was the battery...i also got new terminals.....
lazyboyz69
Postby JAYDEE23 » Wed Jul 27, 2005 11:01 am
mine is alt or bad connection also..a bad batt/good alt usually will still run once started..adding a new batt will remedy the problem immediately but it will be back if its the alt
test your alt w/ a mulitmeter while the car is running to be safe and be sure it read between 13-14 volts
or you can buy an alt tester for a few bucks which will do the same thing
a bad connection is a possiblity also just keep and eye on it for a week
JAYDEE23
