SolaraGuy.com • View topic - soaked floor driver side-rear...
Postby hehateme11 » Thu Jul 28, 2005 2:47 pm
I have a 99 sle v6 with several mods. The problem I have is the floor in the rear driver side is SOAKED. Has anyone else come across this problem?? If so, how did you fix it?? I assume that there is a clog. Someone please help. Thanks!
hehateme11
Postby late2wake » Mon Aug 01, 2005 2:14 am
I had a nice leak on my passenger side of the car. This was due to the ac condensation hose knocked out of its grommet to the bottom of the car.
This resulted in moldy smells and such and had to let it dry for at least a day.
My driver's side; however, was completely dry.
late2wake
Postby RichP » Tue Aug 02, 2005 1:24 pm
Check your a/c evaporator core drain hose. It is under the car right where the front passenger’s feet would be. I ran long zip tie up the hose (like a snake) and opened up the hose. You will be surprised by the amount of water up in there. I would also vacuum up the wet floor ASAP to prevent mildew.
RichP
Postby hehateme11 » Tue Aug 02, 2005 3:00 pm
Thanks for the tip RichP
hehateme11
