SolaraGuy.com • View topic - WTF is up with my window
Postby lilm » Fri Jul 29, 2005 11:30 am
ok well my drivers side window has stopped working......it did this a LONG time ago but after about an hour it started working again....and i thought it was just the weather cause it was unusually cold but now its like 95-100 degrees outside and it stoped working.....any sugesstions??
lilm
Postby Jai_Jai_Binks » Fri Jul 29, 2005 1:10 pm
Dude - you just described the usual symptoms of a 'worn' out regulator (working sometimes and not working other times). It happened on my camry, so sometimes you feel like it all works and don't wnat to spend..other times it doesn't and you scratch you head???
Cheapest fix would be for you to talk to matt...he's really a cool guy at HTC. I'm sure he would be able to 'hook' you up (his username is Negative at HTC). For all you know you may just need to re-lube everything and it might work...i'm sure he can take a peek and let you know...
Postby captainpimp » Sat Jul 30, 2005 7:40 am
dude, i had the same symptoms.....broken regulator.
apexautoparts.com - $100 shipped, did the repair myself. it was very easy. if you're mechanically inclined, you dont even need a haynes manual.
brian
captainpimp
Same Problem
Postby rossman945 » Fri Aug 12, 2005 1:37 pm
Today when I got in my car, my window stopped working. Where is the regulator located at?
rossman945
Postby hari-bhari » Fri Aug 12, 2005 10:05 pm
my drivers side window has been having issues, but i think mine is some problem in the switch. it feels like its getting jammed sometimes, but if i open and shut the car door enough, it works fine again. any ideas?
hari-bhari
Users browsing this forum: Google [Bot] and 33 guests
