SolaraGuy.com • View topic - 2000 V6 Solara Coil Test - HELP
Postby Paladin06Greg » Sat Jul 30, 2005 3:51 am
Good Morening Guys,
Could someone please remove the electrical connector from one of your coils. Then check the resistance across the pins inside the coil. Please set your meter to 200 for this OHMs check.
PS -It's very sensitive and a low reading.
Thx all.
Greg A
Paladin06Greg
Torqued Solara
Torqued Solara
Postby JAYDEE23 » Thu Aug 04, 2005 1:07 pm
did you get the reading? if not i will post in about an hour or two..after work..
JAYDEE23
Postby noodlerooney » Fri Aug 05, 2005 5:40 pm
From the Factory Repair Manual:
Model Year 2000
_____________COLD____________HOT
5S-FE:
Secondary____9.7-16.7Kohms____12.4-19.6Kohms
1MZ-FE:
Aisan made:
Primary_______.7-.94ohms_______.85-1.10ohms
Secondary____10.8-14.9Kohms___13.1-17.5Kohms
Diamond made:
Secondary____6.8-11.7Kohms____8.6-13.7Kohms
15,001 miles, Garage Queen
noodlerooney
