SolaraGuy.com • View topic - Keyless locking problem after HU install
Postby Guest » Sun Dec 15, 2002 6:32 pm
I just got doing hooking up my new Clarion 825 indash. Now the locking porting of the keyless entry doesn't work. It will unlock fine but it wont lock the car. What gives anyone else ever have something similar.
Guest
Postby Gunman » Sun Dec 15, 2002 6:47 pm
you replaced the headunit only? did you go and mess withthe factory amp behind the glove box and perhaps unplug one of the harness?
Gunman
Postby ZXLNT » Sun Dec 15, 2002 7:39 pm
Nope I just unplugged the factory radio and hooked the wiring harness to the plugs that go to the speakers. U have to unplug them from the amplifer and plug those into the aftermarket radio.
ZXLNT
Postby Gunman » Sun Dec 15, 2002 10:06 pm
try and plug your factory unit back and see if anything changes, if that doesnt work i can look up the lock wire and location and see if you can directly input an negative pulse to see if they still operate.
Gunman
Postby ZXLNT » Mon Dec 16, 2002 5:41 am
Yeah that will be the next step plugging in the stock radio again and see what happens. Also I noticed that the dome light is not turning on when I use the remote. I'll play around with it a little bit today and see what happens. I didn't have to time mess with it last night, it was dark and cold when I was done.
ZXLNT
Postby Gunman » Mon Dec 16, 2002 10:10 pm
interesting, before you go back and rip the radio out make sure to check all your fuses first :-?
Gunman
Postby Guest » Sun Dec 22, 2002 10:07 pm
Well for whatever reason. Now that I have the HU all done and permanent everything is working.
Guest
Users browsing this forum: Google [Bot] and 14 guests
