SolaraGuy.com • View topic - Acceleration
Acceleration
Acceleration
Postby SLOW-ARA » Mon Aug 08, 2005 5:50 pm
whats up people i am just curious about the acceleration of the solara... first of all i have been doing 0-60 test and am getting like 10 seconds maybe 9.5 whatever.... secondly, when on the highway say, going around 65 give or take if you decide to put the pedal all the way down (floor it) does it hesitate/engine thinking about going then go or is it suppose to be a quick response.... I have a v6 sle auto(sadly) stock as of now waiting for my K&N drop in to get here hoping this might help a LITTLE... im just wondering if my car should be quicker, i mean 10 second 0-60 is kinda sad... not kinda IS sad! thanks
SLOW-ARA
Postby Mandarinsolara » Mon Aug 08, 2005 6:29 pm
something doesnt sound right about that.
thats too slow. and u are even in cooler air up there
Mandarinsolara
Postby Strider327 » Mon Aug 08, 2005 6:32 pm
I highly doubt its 9.5 or 10 seconds going to 0-60 in a V6. Its about 7.5 or a little higher I believe, I don't remember the actually numbers. 9.5-10 are usually a I4 times. And yes toyotas are known to hesitate on acceleration.....its been a common problems for years. So you are not the only one that's having this problem. If you want to go faster supercharge it! Or slap on some basic bolt ons, a K&N drop in filter is not gonna increase power by much maybe 1 or 2 HP. Your better off Creating a CAI or buying a Injen CAI. At least you'll be able to feel the power and get maybe 5-7 HP out of that. Check out my intake:
www.cardomain.com/id/calvin327
I got a short ram Injen and custom extended myself.
Calvin
Strider327
Postby bassthrive » Mon Aug 08, 2005 9:27 pm
All i know is my 1st gear is weak until it gets over 4k, probably due to the cat-back. 2nd gear pulls like a champ.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby dominoSLEV6 » Mon Aug 08, 2005 10:07 pm
Well I don't know what my exact 0-60 is, but on my track slip I hit the 1/8 in 10.485@68.93 mph. I'm an auto SLE V6 W/ Injen SRI which doens't do that much. So I dunno exactly where it is that I hit 60.
I dunno if that helps. BradOwens had one of those things you connect to your car that tells you all that fun stuff.
-chris
dominoSLEV6
Postby Turbosolara » Mon Aug 08, 2005 10:10 pm
hestitation because it is an automatic. most of automatic car does that. it is like its asking you "oh you floored it...are you sure, are your sure? are you sure? here you go......."
thats why manual car can beat auto easily.
Postby SLOW-ARA » Tue Aug 09, 2005 8:24 am
bassthrive... it seems as if my whole first gear is weak, doesn't seem to pull after a certain rpm range.. yeah second gear does pull... also is there a way to program your ecu to shift later in the lower gears... i know for trans am they have a kit you can purchase that you can do this for autos i was wondering if there was one out there for us
SLOW-ARA
Postby TheTamago » Tue Aug 09, 2005 10:02 pm
when was the last time u had the tranny fluid flushed? And cooler/oil changes?
TheTamago
Postby SLOW-ARA » Wed Aug 10, 2005 7:17 am
don't know bout the tranny flushed but i did get an oil change recently, plus on synthetic so thats not it.... im just wondering if there is some internal wrong with my engine for it to be that slow
SLOW-ARA
Postby Jon11582 » Wed Aug 10, 2005 7:27 am
Are you using 91+ octane?
2000 Black Solara SE
Jon11582
Postby SLOW-ARA » Wed Aug 10, 2005 8:33 am
actually i am using 93
SLOW-ARA
Postby lazyboyz69 » Wed Aug 10, 2005 1:09 pm
my cousin works at toyota.... he said most toyota have problems with the throttle body causing slow accleration.... so try to clean out your throttle body.... and sounds like your trans might be going bad if it takes that long to pick up..... second 60 refers to 60' feet at the track not 0-60mph....
lazyboyz69
Postby SLOW-ARA » Wed Aug 10, 2005 6:05 pm
ill try cleaning the throttle body... do a search for it on here some wehre.... maybe a tut. for it... unless someone has a link thatd be reaal cool
SLOW-ARA
Postby WTF?? » Wed Aug 10, 2005 6:56 pm
SLOW-ARA wrote:ill try cleaning the throttle body... do a search for it on here some wehre.... maybe a tut. for it... unless someone has a link thatd be reaal cool
http://www.solaraguy.org/viewtopic.php? ... ottle+body
Retired... its been fun Image
WTF??
0-60mph
Postby tiz_ard » Wed Aug 10, 2005 7:21 pm
My friend has a computer to calculate the 0-60 times and my car with nothing done and also 100,000 miles is still getting around 7.3 - 8 seconds.
tiz_ard
Users browsing this forum: Google [Bot] and 33 guests
