Front Brake Install
I just finished installing my front brakes with just and a breaker bar hand tools. No problems as of yet. I am much man!
- ~Spadwaller~
- SolaraGuy Street Racer
~Spadwaller~ wrote:I am much man!
1SexySolaraHottie wrote:You know how to work on cars as well?? Would you help me lower my car, please Spaddy.
Amanda
~Spadwaller~ wrote:I having grinding noises on my front pads, and I think my slotted Brembo rotors are getting warped but I'm not sure. Could this be because I'm using semi metallic pads instead of the ceramics?
SpeedSTARs wrote:~Spadwaller~ wrote:I having grinding noises on my front pads, and I think my slotted Brembo rotors are getting warped but I'm not sure. Could this be because I'm using semi metallic pads instead of the ceramics?
Sup Bro,
Are the pads seated properly in the liners (in the calipers)? Is this grinding sound present when your from a roll (while your driving)? And, last but not least, did you clean the pistons in the caliper to ensure that the brake pistons weren't sticking?
It could be the pads that the pads are not seated properly in the calipar.
Or, the bolts that hold the calipers are loose or too tight (just check the torque specs from the OEM settings/specs). Number three, it could be that the brake piston on one of the caliper are sticking. Hopefully this helps out.
~Spadwaller~ wrote:SpeedSTARs wrote:~Spadwaller~ wrote:I having grinding noises on my front pads, and I think my slotted Brembo rotors are getting warped but I'm not sure. Could this be because I'm using semi metallic pads instead of the ceramics?
Sup Bro,
I only hear the sound when i'm comming to a slow roll stop, and I used brake cleaner to clean inside the pistons. I now noticed that my front rotors don't feel flat anyone they have a groove circle all around the outer rim like the front pads are pushing too hard on the rotor. Anyone know the torque spec for a 2000 solara SLE? Is there a special torque telling tool?
~Spadwaller~ wrote:When I go in reverse after the car cools down it feels like the pads are stuck togther on the rotor help!
:o Are your sliding pins seized/ rusted? Sound like you might need to apply some antiseize on those pins.
~Spadwaller~ wrote::o Are your sliding pins seized/ rusted? Sound like you might need to apply some antiseize on those pins.
The "sliding pins" are the 2 screws on the torque plate right?
Users browsing this forum: Google [Bot] and 38 guests
