SolaraGuy.com • View topic - Blueish White smoke at start up...
Postby 2001SoLa » Tue Aug 16, 2005 7:09 pm
This only happens at the start up of the car. Also is has a really wierd smell....Almost like an electric burning smell????? the car runs Perfect!!!! Other then the smoking at start up. it goes away almost right away after the start up. This only happens if the car sit for more then 3-4 hours. Does any one have a idea what this mite be? Almost forgot it is a 4 banger as well. Thanks in advance!!!!
John
2001SoLa
Postby DatSRBoi » Tue Aug 16, 2005 7:23 pm
For the smoke part thats normal..But for the electric smell your saying, it might be your starter
Postby 2001SoLa » Tue Aug 16, 2005 7:33 pm
But the smell is only there when I start the car. Less then a min or so it is gone.
2001SoLa
Postby ~Spadwaller~ » Tue Aug 16, 2005 7:36 pm
:o This sounds serious get the dealer to check it out, before the unthinkable.
~Spadwaller~
Postby trioptimum » Tue Aug 16, 2005 10:01 pm
I have a TINY amount of white smoke at startup sometimes, only if the car sits for a fewdays usually, dealer said it's normal.
The smell could be unrelated but serious, electric smells are never good, especially if smellable from inside the car, definitly get it diagnosed and ask about the smoke at the same time if it seems related.
________________________________
2005 Infiniti G35X AWD Sedan
1999 Toyota Camry Solara SLE V6
trioptimum
Postby Yanks0114 » Tue Aug 16, 2005 11:18 pm
blue smoke is typically because you are burning oil
Postby Yanks0114 » Tue Aug 16, 2005 11:48 pm
you might also want to check out this thread
http://www.solaraguy.org/viewtopic.php?t=9504
Postby 2001SoLa » Wed Aug 17, 2005 3:53 am
Thanks guys I will get it looked at then! That thread helped out alot! Thanks again.
John
2001SoLa
Postby Turbosolara » Thu Aug 18, 2005 1:52 am
white smoke might means you are leaking some coolant while black smoke means you are leaking oil. check your coolant level if it is drop over time, if so, thats means your headgasket is going out.
Postby SC V6 » Thu Aug 18, 2005 6:12 am
could mean a few different things.. get it checked out asap.. cause our motor does have a sludging problem
SC V6
Postby Fletch » Thu Aug 18, 2005 6:44 am
Black smoke also means you are running fat.
2006 Legacy GT spec.B
Fletch
Postby WTF?? » Thu Aug 18, 2005 6:47 am
blue and white smoke???? sumone dumped sum smirfs into your muffler!
Retired... its been fun Image
WTF??
Postby JAYDEE23 » Thu Aug 18, 2005 8:39 am
I THOUGHT OIL BURNING WAS BLUEISH WHITE?
if you are burning antifreeze there is a dangerous but easy way to tell.
get a tast of the smoke in the air..if it is sweet you are burning antifreeze. just dont breath it in or swallow it!!!!!!
JAYDEE23
Postby JAYDEE23 » Thu Aug 18, 2005 8:44 am
oops double post
JAYDEE23
Postby Jon11582 » Thu Aug 18, 2005 9:14 am
Blue smoke is a typical sign for burning oil. But Yanks said that already so I wasn't going to reiterate it.
I believe Antifreeze smokes white...I remember from when my water pump blew.
2000 Black Solara SE
Jon11582
