SolaraGuy.com • View topic - rearview mirror
rearview mirror
rearview mirror
Postby hoo024law » Wed Dec 18, 2002 12:22 pm
Has anyone had any experience in installing the auto-dimming toyota rear-view mirror? Supposedly it needs 12volt power. How does that connection work? Thanks!
hoo024law
Re: rearview mirror
Postby PureNocence » Wed Dec 18, 2002 3:55 pm
hoo024law wrote:Has anyone had any experience in installing the auto-dimming toyota rear-view mirror? Supposedly it needs 12volt power. How does that connection work? Thanks!
What's the benefits of getting that auto-dimming mirror? I just got a plain 'ol Broadway one...and it seems to work for me :)
PureNocence
Postby NASTY » Wed Dec 18, 2002 6:06 pm
the benefits?
it dims by itself, whats not to like?
'01 SLE V6
NASTY
Postby Blaze » Wed Dec 18, 2002 6:18 pm
yea my moms bmw has an auto dimmin mirror, its phat gets dark if sun or lights hit it.
Blaze
Postby NASTY » Wed Dec 18, 2002 6:26 pm
i thought it was standard on all solaras...
'01 SLE V6
NASTY
Postby Blaze » Wed Dec 18, 2002 6:30 pm
nope :\
Blaze
Postby Flipside909 » Wed Dec 18, 2002 6:36 pm
NASTY wrote:i thought it was standard on all solaras...
Nope standard on SLE only.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby ChiroCop » Wed Dec 18, 2002 7:25 pm
This is my first car with the auto-dimming mirror. It's great. It senses the lights from behind and dims to a dark blue when needed. No flipping back and forth. I see that a mirror is also made with a compass. Is that a straight-forward rewire/install?
'02 SLE V6 Convertible White Pearl / Black Top
ChiroCop
Postby Missay » Wed Dec 18, 2002 7:46 pm
i don't think it's all it's cracked up to be...when i have the dimmer on i can hardly notice the difference..things just kinda look green :P
Melissa
Missay
SolaraGuy Ambassador
Postby Jai_Jai_Binks » Thu Dec 19, 2002 9:25 am
Our camry's got the autodimming with thermostat...the auto dimming worked nicely until we got our rear windows tinted (limo tint)...so now in reality...i don't see a difference...however...i would recommend the one with compass/thermostat..thats a nice feature to have.
(i wish my solara had the same!!)
Postby SpikedMantis » Thu Dec 19, 2002 9:31 am
Missay wrote:i don't think it's all it's cracked up to be...when i have the dimmer on i can hardly notice the difference..things just kinda look green :P
I think it does make a difference. I reduces a lot of the brightness from headlights behind you. I was driving at night and kept switching on and off to see the difference. Also, I heard green is the easiest color on the eyes.
SpikedMantis
Postby 01RDSLE » Thu Dec 19, 2002 11:12 am
hoo024law,
you'll tap into power in the JB behind the knee bolster left of the steering column. :-? Route the wiring from the mirror being carefull to trap it under the headliner without damaging the sides of the liner (be careful here since the hliner is glued at the ends (about 25~50mills inboard). you'll need to pull the trim off the A-pillar and route the harness this way then connect to the upper right portion of the JB (should be a 6 way connector).
DNM's work great and are worth the investment if connected correctly and you or the tech do little damage to the trim and headliner. Adding a mirror with tinted windows is a waste of money since the mirror works by guaging the amount of light it recieves from the rear of the vehicle at night, which then the sensor turns the inner mirror.
my wife has this on her Bimmer 02MY 325CI (uuurraaahhhhh) and also on the side mirrors. it works fantastic. 8)
good luck. Also, you can check a service manual at your local garage to get the exact location in the JB.
Wishin for warmer weather!!!
01RDSLE
Re: rearview mirror
Postby Yanks0114 » Thu Dec 19, 2002 1:17 pm
Whats the broadway mirror do, Is it just a wider mirror for more visibility
Postby krook » Thu Dec 19, 2002 1:19 pm
yep.
krook
Postby dbanker » Wed Feb 19, 2003 10:10 am
I've got the auto-dimming mirror and whenever my stereo is playing at relatively loud levels it makes a rattling noise. I've looked into it and it's because the actual mirror is not secure in the mirror housing. I'm wondering what I can do to reduce the vibration of the mirror. If I could somehow place something behind the mirror I bet that would make it more secure. Any ideas?
dbanker
