SolaraGuy.com • View topic - Broken Springs
Broken Springs
Broken Springs
Postby FLASH » Sun Aug 21, 2005 4:40 pm
I just bought all new shocks and springs. I slid into a curb on ice back in winter, then a few days ago hit a pothole on the same side. I noticed I was rubbing all the time and i saw the wheel was almost tucked under the fender so i jacked it up and took off the wheel to see the spring was cracked in half and just sitting on itself like a sandwhich.
So now my whole wheel is basically just on the shock. I got new ones on the way, but how unsafe would it be to drive just to work and back (about 15 miles)? I'm trying to borrow a car from someone or get rides.
PS - I bought the suspension used and they now have a total of almost 50,000 miles on them so I was expecting to replace them soon anyway. Moral - dont buy used suspension parts!
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby SpeedSTARs » Sun Aug 21, 2005 5:01 pm
Dang Bro,
Sounds like you had the same problem I did a couple of months ago. My spring snapped on the passenger side rear. IMHO, you might want to replace the strut where the snapped spring is on. Or even check if the strut is blown. It is visible from the greasy piston tube and the slow rebound of the strut. The grease is the lubricant and the exposed grease that is visible is from the blown seal inside the strut squirting out. Just check it out and be prepared to replace the strut. I wish you luck Bro.
SpeedSTARs
Postby SleeperSolara » Sun Aug 21, 2005 7:17 pm
Man that sucks man.
Yeah check that shock it if leakin'.
Yeah it would be a good idea to borrow a car for the time being.
Because if you drive wit just the strut you could be doin' some unknown damage to the rear part of the suspension.
Postby 1st Gen Sol » Mon Aug 22, 2005 10:38 am
What was your previous suspension setup that it snapped ? ?
Hopefully this isn't a common problem if I'm guessing your previous setup is the one listed on your sig. b/c I'll be going with that setup very soon.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby FLASH » Mon Aug 22, 2005 12:41 pm
It was eibach/tokico...the springs were so used they were even rusty.
==FLASH==
FLASH
Postby DatSRBoi » Mon Aug 22, 2005 1:03 pm
Makes me worry about my car, and I dont even abuse the suspension...
Postby 1st Gen Sol » Mon Aug 22, 2005 1:04 pm
Hopefully I won't have that problem.
Whats your new setup gonna be ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby FLASH » Mon Aug 22, 2005 2:14 pm
I'm going to stay with tokico/eibach. I dont think the problem was with the manufactured parts, just the age and condition of them when I bought them, then my unfortunate events with them. It just sucks.
==FLASH==
FLASH
Postby SleeperSolara » Tue Aug 23, 2005 11:41 am
Good luck man.
